Go to Post More inspired students, more community involvement, less drain on the mentors... Sounds pretty swell to me! - Karthik [more]
Unread 17-01-2007, 22:36
JakeC JakeC is offline
FRC #1535 (The Knights of Alloy)
Team Role: Driver
JakeC is an unknown quantity at this point
Re: mecanum programming
If you use tank drive the OMNI wheels will deffinately help, but they are a pain to build if you are... 1535 used them for the past 2 years when they were known as 1596, dont know if we're ghoing that way again.
ATTENDING:
Wisconsin Regional 2009
Greater Toronto Regional 2009- Winners Engineering Inspiration Award
Championship
Lets Go TKOA 1535!
Formally Known as the 1596 International Instigators
Unread 22-01-2007, 13:41
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
We're going mecanum for our bot, we're rookies. I'm the programmer, I came up with this code, haven't tried it yet but it's simple and should work perfectly. (cause we don't have a bot yet - only 2 weeks into the six) I also have a program I made that simulates mecanum movement with my drive programming. Here's a section of the user_routines.c with the default drive commented out and my drive put in. It shows which pwm's are which motors, and has a spot for inverting motor outputs if needed.
 /*---------- 1 Joystick Drive ----------------------------------------------
  *  This code mixes the Y and X axis on Port 1 to allow one joystick drive.
  *  Joystick forward  = Robot forward
  *  Joystick backward = Robot backward
  *  Joystick right    = Robot rotates right
  *  Joystick left     = Robot rotates left
  *  Connect the right drive motors to PWM13 and/or PWM14 on the RC.
  *  Connect the left  drive motors to PWM15 and/or PWM16 on the RC.
  p1_x = 255 - p1_y;
  p1_y = 255 - pwm05;
  pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
  /* here's my mechanum drive, ignore all of the above default code
  here's which pwms are which motors
  14   13
  15   16
  double motor[4] = {127.0,127.0,127.0,127.0};
  // actual axis mixing
  motor[0] = p1_y - p1_x - p1_wheel + 255.0;
  motor[1] = p1_y + p1_x + p1_wheel - 255.0;
  motor[2] = p1_y - p1_x + p1_wheel;
  motor[3] = p1_y + p1_x - p1_wheel;
  // limit motor outputs to 0 - 254
  for (int n=0; n<4; n++)
      if (motor[n] > 254.0)
          motor[n] = 254.0;
      if (motor[n] < 0.0)
          motor[n] = 0.0;
  // invert motor outputs here. Ex:
  // motor[0] = -1.0 * motor[0] + 254;
  // add .5 so type cast to int (pwm_13 = motor[0];) is rounded,
  //   not always rounded down
      motor[n] += .5;
  pwm_13 = motor[0];
  pwm_14 = motor[1];
  pwm_15 = motor[2];
  pwm_16 = motor[3];
EDIT:
And of course, since this is c and not c++, you have to move the variable declarations to the beginning of the subroutine.
In other words, put
int n=0;
right after
void Default_Routine(void)
and change the for loops from
to
for (n=0; n<4; n++)
there's my edit
Use the following program, copy and paste to a compiler, to see what my mecanum drive does. It gives you the total diagonal vectors (as that's how the mecanum wheels push, and they roll freely in the other diagonal, each pair of wheels pushes in a different diagonal), then converts those into the horizontal/vertical force vectors, then converts that into the total movement vector and the angle of movement. It also gives the rotational vector force. Vector outputs are such that "where 100 = the result of one motor's full, direct power" as is commented in the program. It also gives each motor's output (keep in mind 127 is stopped, 254 is forward, 0 is backward) You give in input for each joystick axis where 100 = full forward or right and -100 = full backward or left. Y axis is joystick up/down, makes the bot move forward/backward. x axis is joystick left/right, makes bot strafe left/right. z axis is joystick twist or throttle wheel or a second joystick's left/right, and makes the bot spin to the left/right. It converts the -100 - 100 input to 0-255 input. It's all in double for accuracy, so feel free to input stuff like 75.678. Notice how when going full forward you have a certain forward force, but when you add to that a full spin right the forward speed halves. Then when you stop moving, the full spin to the right doubles in speed. That's cause some of the motors' force have to be redistributed from movement to turning, slowing the movement. That's how my nifty mecanum drive code works . Normal 4-wheel, 4-wheel-drive does the same thing. When you're going full forward and decide to turn at the same time, you will slow down a bit.
#include <iostream>
#include <cmath>
using namespace std;
#define PI 3.141592654
// converts degrees to radians
double rad (double deg)
    return deg * ( (2.0*PI)/360.0 );
// converts radians to degrees
double deg (double rad)
    return rad * ( 360.0/(2.0*PI) );
// actual program
main()
    // declare variables
    double x=127.5, y=127.5, z=127.5,
           motor[4] = {127.0,127.0,127.0,127.0},
           fwdright = 0.0, fwdleft = 0.0, turnright = 0.0,
           fwd = 0.0, right = 0.0,
           angle = 90.0, total = 0.0;
    while(true)
        // get joystick axis inputs
        cout << "Y Axis: ";
        cin >> y;
        cout << "X Axis: ";
        cin >> x;
        cout << "Z Axis: ";
        cin >> z;
        // change axis inputs (-100 - 100) to 4-bit inputs (0 - 255)
        x = (x+100.0) * (255.0/200.0);
        y = (y+100.0) * (255.0/200.0);
        z = (z+100.0) * (255.0/200.0);
        motor[0] = y - x - z + 255.0;
        motor[1] = y + x + z - 255.0;
        motor[2] = y - x + z;
        motor[3] = y + x - z;
                motor[n] = 254.0;
            if (motor[n] < 0.0)
                motor[n] = 0.0;
        // round really small motor numbers to 0
            if (motor[n] < .001)
                motor[n] = 0;
        // show motor outputs
            cout << "\nMotor " << n << ": " << motor[n];
        // change motor 4-bit outputs (0-255) to display (-100 - 100)
            motor[n] = (motor[n]-127.0) * (200.0/254.0);
        // calculating movement vectors and rotational vector
        //   where 100 = the result of one motor's full, direct power
        fwdleft   = motor[0] + motor[2];
        fwdright  = motor[1] + motor[3];
        turnright = motor[1] + motor[2] - motor[0] - motor[3];
        // calculating forward and right movement vectors
        fwd   = sin( rad(135.0) ) * fwdleft +
                sin( rad(45.0 ) ) * fwdright;
        right = cos( rad(135.0) ) * fwdleft +
                cos( rad(45.0 ) ) * fwdright;
        // calculating total movement vector and angle
        total = sqrt( pow(fwd, 2) + pow(right,2) );
        angle = deg ( atan2(fwd, right) );
        if (angle < 0)
            angle += 360;
        // round really small vector numbers to 0
        if ( fabs(fwdleft) < .001)
            fwdleft = 0;
        if (fabs(fwdright) < .001)
            fwdright = 0;
        if (fabs(turnright) < .001)
            turnright = 0;
        if (fabs(fwd) < .001)
            fwd = 0;
        if (fabs(right) < .001)
            right = 0;
        if (fabs(total) < .001)
            total = 0;
        if (fabs(angle) < .001)
            angle = 0;
        // show all vectors
        cout << "\n\nTurn Right vector: " << turnright
             << "\n\nForward Left movement vector:   " << fwdleft
             << "\nForward Right movement vector:  " << fwdright
             << "\n\nVertical movement vector:   " << fwd
             << "\nHorizontal movement vector: " << right
             << "\n\nTotal movement vector:       " << total
             << "\nTotal movement vector angle: " << angle << " degrees";
        getchar();getchar();
        cout << "\n-----------------------------------------"
             << "---------------------------------------\n";
hope this helps
Last edited by LieAfterLie : 22-01-2007 at 21:32. Reason: changed motor ouput 127.5's to 127.0's and 255's to 254's
Unread 22-01-2007, 13:49
FRC #2028
oh yeah and if u want a gyro for true holonomic movement (as im planning to do) just turn the xy joystick inputs to magnitude and direction, then offset the angle by the gyro's input, then convert back into the joystick xy input and run through the drive like nothing happened. simple trig. This makes it so that no matter what direction the bot is facing, forward always makes the bot move 'up' and backward always makes if move 'down' etc. even if 'down' is actually the bot's forward-left.
Unread 22-01-2007, 19:06
The valid range of pwm control outputs is 0-254, with 127 being neutral. You should change all your 127.5 values to 127, and all your 255 values to 254.
Unread 22-01-2007, 21:23
FRC #2028
thanks very much, didn't know that - thought it was normal 4 bit. I haven't tried it yet, guess it wouldn't have worked. The joystick serial inputs are still 0-255 right?
Unread 22-01-2007, 22:29
Do you mean "8 bit"? Yes, the pwms are 8-bit values, but they're defined to have 127 as neutral and go +/- 127 from there.
There aren't any joystick serial inputs. Did you mean "game port"? The joystick values are typically set up with 127 being neutral as well. I can't remember whether 255 is a possible value, but it works to assume the valid joystick range matches the valid pwm range.
Unread 23-01-2007, 00:35
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Just as an general guideline for programming with the RC: Avoid the use of floating-point numbers whenever possible. It seems as if you have calculated everything as doubles for the sake of rounding accuracy later on. It is not very helpful to use doubles in your actual robot code, because a difference in the PWM outputs by 1, will be extremely negligible.
As for the whole max joystick value issue, you can always just quickly check it by printing out the value of the joystick inputs in your code. Either way, you can simply just check to see if your variables have overflowed at the end of your code.
Another suggestion: If you are going to use a temporary variable to hold your PWM outputs while they are being calculated, it may make more sense to store them as signed chars instead of unsigned chars, since they intuitively make more sense. Then at the end just add 127 to your values.
Unread 23-01-2007, 13:29
FRC #2028
they're serial ports. ill use the operator interface leds to test for 255 later, and use signed chars. Thanks. And yes, I meant 8 bit. I should've taken another second to think about it, I was off by a power.
Unread 23-01-2007, 14:06
Joysticks plug into the 15-pin game ports. The only serial port on the OI is the dashboard connector. (Well, there's the radio modem connector, but that's special. And there's serial stuff on the competition port when connected to the field electronics, but that's even more special.)
Don't use signed chars to store joystick values. They only go from -128 to +127, and would be essentially inside out for motor control. The negative value of greatest magnitude would equate to the slowest forward speed, and the smallest positive value would equate to the fastest negative speed. For reading the joystick values and setting the pwm values, you want unsigned chars. (What you do with those values is your own business; you can obviously subtract 127 from them and get your signed value for internal program use if you like.)
Unread 23-01-2007, 15:49
FRC #2028
Thanks again, you've been very helpful. Unsigned it is. Personally I do understand the 0-254 more than -128 - +127, so I guess I'll use unsigned, although it doesn't really matter. By serial I simply meant not parallel, by that definition a game port is a kind of serial port (I do believe...). The default code calls it serial too, that's where i got it from. But it's not the standard computer connector for serial. I can't update the code, I guess it's too long ago. If anyone really wants the working one say so.
Unread 23-01-2007, 20:36
The joystick ports each have four analog inputs and four switch inputs simultaneously, plus either another four switches or four LED drive outputs. I'd say that's at least as parallel as a standard parallel printer port. Can you point me to the spot in the default code that mentions the joystick ports as "serial"? I can only find references to the actual RC serial ports.
Unread 24-01-2007, 14:04
Phantomechanics's Avatar
Phantomechanics Phantomechanics is offline
phantom mechanics
AKA: joey
FRC #2028
Team Role: Student
Phantomechanics is an unknown quantity at this point
Send a message via AIM to Phantomechanics
"printer ports are serial", lieafterlie
Unread 28-01-2007, 13:45
Mib Mib is offline
AKA: Aaron Clay
FRC #1741 (Red Alert Robotics)
Mib is on a distinguished road
Send a message via AIM to Mib Send a message via MSN to Mib Send a message via Yahoo to Mib
ours is set up with 255 being full power forward, 127 being neutral and 0 being full reverse
the program also sets it up for the wheels on either side to be linked with each other, so it can be either side (one wheel from each axel) being controlled
Aaron M. Clay
Programming Consultent
www.GameCopyWorld.com
amclay (@) purdue.edu
Mecanum Suspensions Rob2713g Technical Discussion 12 01-12-2006 08:27
Mecanum Rob2713g Technical Discussion 13 03-11-2006 14:16
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
