Go to Post People are human, refs are human. The refs did the best they could do at the time. - Andy Baker [more]
Unread 23-01-2007, 13:56
Corporat's Avatar
Corporat Corporat is offline
Mama mia, that'sa one spicy robot!
AKA: Anthony R
FRC #1676 (Pascack Pioneers)
Team Role: Animator
Corporat will become famous soon enoughCorporat will become famous soon enough
Send a message via AIM to Corporat Send a message via Yahoo to Corporat
Trouble with superspray smoke effect
I made a power plant for our animation and it seemed to be fine until i rendered it this morning. A gap in the smoke showed up randomly, and all of the frames turned out exactly the same. What's wrong here and how can I fix it?
(The gap is right above the horizon on the right)
PS: I am using 3ds max 8, but 9 is available if I need to use it.
Unread 23-01-2007, 14:06
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: Trouble with superspray smoke effect
Have you tried adjusting the location of the smoke and messed with the settings some to see if it does this regardless of where it's positioned?
Also, you said all of your frames turned out the same? Do you mean that every one of them is the same, as in no animation? You have to set it to render a range of frames, not sure if I misinterpreted what you were saying.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 23-01-2007, 14:23
Corporat's Avatar
AKA: Anthony R
Team Role: Animator
well, i tried moving the supersprays around, and I had no luck. Then I tried moving the perspective camera around and the space was still there.
And by no change, I meant there was still a space in the smoke in the same place on every frame. It animates correctly.
Unread 23-01-2007, 15:22
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Make your smoke stacks taller to cover up the space? Might work
Unread 23-01-2007, 15:52
Corporat's Avatar
AKA: Anthony R
Team Role: Animator
i've tried this, and i guess it works, im just curious why this keeps happening
oh well, thanks for helping
Unread 23-01-2007, 19:48
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
You should try to learn Particle flow, its much more flexible than superspray/snow or any other particle arrays that came before 3dsmax 6.
But about your question, is it emitting some particles, then stopping the emission for about two or three frames, and then starting emitting again?
If so, try the settings of "particle birth/speed", i dont really remember exactly where it is, and i don't have 3dsmax in this machine =)
The smoke material is cool indeed =D. Noise gradient? But i think power plant's smokes are heavier, and next to grey/white, not black as your image show. look this image:
http://www.ens-newswire.com/ens/pics11/coalplant.jpg
Good luck =)
Unread 24-01-2007, 18:33
Corporat's Avatar
AKA: Anthony R
Team Role: Animator
no, its not that. basically, once the particles reach a certain height, they dissapear for a short while, then come back.
and i know that it is more like steam than smoke coming out of the wide smokestacks (or whatever you call them), but I'm looking to make the scene look overall dark and unclean. i've worked on it a lot after i posted the picture here, and it's really coming along. again, thanks for all of your help
Unread 24-01-2007, 18:55
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
To make it overall dark you need to go into effects and add fog
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Making a smoke machine forcefully blast out the smoke. sanddrag Technical Discussion 16 18-12-2005 23:46
Encoder code with hall effect sensors help brownster Programming 10 19-02-2005 09:23
Trouble with gear box dmellich Motors 6 17-01-2005 09:41
Trouble with pwm outputs misterikkit Programming 16 17-01-2004 10:56
Trouble with MMH Orders? MrB Kit & Additional Hardware 0 28-01-2003 09:07
