Thread Tools |
Rating:
Display Modes |
Re: how to build a VEX programming module
You can use an in-circuit debugger to program both the master and user processors. You have to open the case to access the connector.
Using the pin designators on the silkscreen of the pc board, here is the pinout: J1-17 PGD on the Master Processor J1-18 MCLR on the Master Processor J1-19 +5v J1-20 no connect J1-21 Port B7 and PGD on the User Processor J1-22 MCLR on the User Processor J1-23 RX2 on the Master Processor J1-24 GND J2-9 PGC on the Master Processor J2-10 GND J2-11 Port B6 and PGC on the User processor J2-12 TX2 on the Master Processor |
After following the directions posted previously in this thread, I managed to build a working programming cable. When using a usb-to-serial converter cable, they somehow mess up the handshaking that is going on to put the Vex microcontroller into programming mode. So to fix that, I had to use a microcontroller to generate the correct signal. So my home made programming module has a microcontroller in addition the the RS232 level shifter. You can take a look at the cable and a video of how it works on my site: www.CrestOak.com. Enjoy!
Please can anyone share their working circuit diagram on how to interface the max232.
One thing that really puzzles me is where and how to connect the program button. Thanks. You can also email me at n0rad2002@yahoo.com.sg Cheers |
Unfortunately, at this time I don't plan on releasing the schematic and source. Right now I'm hoping to use up some of the extra parts I have in making complete cables. However, after that, I might spend the time to create a readable schematic and release the code.
#7
Does the module put the controller into programming mode using the control lines?
#8
Apparently so, but I'm not sure exactly how yet. Can someone explain what the handshake combination is?
I bought my son a VEX kit over the holidays, and wrote a VEX loader for *nix shortly afterward. I made a serendipitous discovery that Mac OS X and Linux trigger programming mode by accident when the port is closed. (FreeBSD does not.) This happens reliably with both the USB/serial adapter and with a direct connection to the serial port on Linux. I'm using the orange programming module that came with the EasyC kit. I can prevent it from happening by dropping RTS using an ioctl() call before the port is closed. Apparently OS X and Linux drop RTS when the port is closed, and this is *part* of the handshake to trigger programming mode. I have tried various combinations of dropping and raising RTS and other control lines, with no success turning on programming mode. Thanks, Jason |
#9
You just need to plug the RTS and CTS into a serial cable that plugs into the computer to successfully complete the handshake.
PIN_LAYOUT |
#10
Now if I have a rs232 to TTL converter that has the following pinouts:
GND RX-> TX<- VCC 3-5v and I'm using a real RS232 pc port. Where do I Connect pins 4-CTS & 6-RTS from the vex programming port? The TTL converter does not have these... Do I connect them directly to the serial port ? Does the TTL converter only need the TX/RX ports to go through it? I dont use a USB to RS232. thanks Last edited by essence25 : 11-19-2009 at 03:36 PM. |
#11
What a useless and deceptive thread in regards to this programing button & cable. Funny thing is there is already a poster above selling this so called "Proprietary" cable for profit.. Way to go protecting the cable secret bs!
#12
1) The thread includes the information you would need to make your own VEX programming cable. I don't think anyone is trying to be deceptive. 2) What cable secret? If you want to buy a factory-made and -supported part you can do so from IFI, and if you want to make your own, you can follow the information here. There are better ways to communicate than through invective and imprecision. Perhaps you can more fully explain what you are trying to say? |
#13
PS: It's not a dead thread - Don't let bullies convince you that tapping into existing information instead of splattering the net with constant ill-informed chatter is a bad thing. "Those who don't know history are destined to repeat it." |
#14
ya i know that but we cant afford the vex kit and we are going to nationals soon
#15
Vex Nationals is in about 10 months.
| Programming - Getting Started | Mark McLeod | Programming | 80 | 04-16-2008 11:37 PM |
| Programming for Vex robots | Jeff K. | Programming | 4 | 11-13-2005 04:40 PM |
| VEX Robotics | vexrobotics | FIRST Tech Challenge | 8 | 03-30-2005 11:25 PM |
| OCCRA Teams - where do you build? | Phil 33 | OCCRA | 7 | 10-28-2004 09:41 PM |
| build new programming (st.louis regional) | nick_champ_2 | Programming | 21 | 02-23-2004 08:55 PM |
