Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 23-01-2007, 16:46
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Which pinions for FP motors and BaneBots 42 mm gearboxes?
Hey y'all,
I have to place an order for two of the BaneBots 42mm gearboxes and I want to order some extra pinions for the Fisher Price motors in the kit. I'm not anywhere near our kit, or I'd just measure it myself, but I'm curious if I ought to be ordering the 3.2mm or 5.0mm bore pinions.
I think I'm after the 3.2mm pinions since the FP motors are a 550-ish can, but better safe than days behind schedule, right?
--Madison--
...down at the Ozdust!
Unread 23-01-2007, 16:56
AdamHeard's Avatar
Lead Mentor
Re: Which pinions for FP motors and BaneBots 42 mm gearboxes?
3.2mm is roughly the same size as a 1/8" shaft, which I believe is what the FP has.
We ordered 3.2mm for our FP's and the banebots and they worked, The 5.0mm would be way too big.
Unread 23-01-2007, 19:26
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
3.2mm. I just ordered the same stuff today, and was curious to see what size...so I took out the calipers and measured the shafts of the FP motors. They are exactly 1/8", which is 3.175mm, which will fit the gears.
Make sure you get a gear puller if your dont have one already. Then you can re-use the ones on the 550's, or have some spare ones lying around (which wouldn't be a bad idea).
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 23-01-2007, 20:04
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
we used the 3.2mm pinions last year for the FP motors and they worked well. We are also moving up to the 42mm gearbox's this year and hope to have better success with them this year. You will defiantly need a gearpuller, and grab a bunch of extra pinions just incase you burn out any FP's.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Are all banebots motors allowed? EnderWiggin Motors 7 11-01-2007 22:27
Motors and gearboxes from the kit Kam1310 Motors 21 10-03-2005 22:26
Motors and gearboxes in the kit Kam1310 Technical Discussion 1 09-03-2005 17:43
Which team do u think used firsts gearboxes the best. 18voltMilwauke General Forum 5 17-04-2003 12:01
Pressure angles for motor pinions Ian Mackenzie Motors 5 10-01-2002 15:05
