Go to Post Ok maybe you cant stop them, but you can utilize that pretty flashing LED pretty darn well! - Andy Grady [more]
Unread 23-01-2007, 17:55
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
pic: prototype of ramp in up postion
Unread 23-01-2007, 17:57
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: prototype of ramp in up postion
This is an interesting design for a lifting mechanism. Have you considered how you'll stow it inside the robot at the beginning of each match?
What sort of material were you considering for your platform?
I'd love to read more details about how you plan to implement this design.
--Madison--
...down at the Ozdust!
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
How long is the ramp, what angle is it at?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 23-01-2007, 18:05
Madison's Avatar
FRC #0488 (Xbot)
Based on the other photo uploaded to CD-Media (http://www.chiefdelphi.com/media/photos/26396?), it appears as if there's no ramp at all. Rather, it's a platform supported by a parallel four-bar linkage. By pulling up upon the top of the linkage with a pneumatic piston, the linkage swings upward and the retracted force of the piston will hold a robot and the platform 12"+ in the air.
This design and ones like it, if they can be made to work properly, are superior to ramps in almost every way, as far as I'm concerned.
--Madison--
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
how do you expect this to work???
Unread 23-01-2007, 18:10
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
its actually a lift so it would be always parrallel to the ground
it would be folded up so it would be perpedicular to the ground. At the end of the game, a pin would be pulled, it would fall down, a robot would drive on it, and then we'd lift it off the ground to the position in the picture above
the platform would be made out of a honeycomb aluminum
unfortunately, we decided since it would weigh about 20lbs a side that it was a little heavy so we're going with something else
Unread 23-01-2007, 18:11
Andrew Blair's Avatar
FRC #0306 (CRT)
Well, I can tell you this much- there is just enough air in four tanks to eek a little more than 150 lbs fourteen inches. How you link it properly in order to let the air do it's work- a bit of an issue.
-Sir Francis Bacon
-Albert Einstein
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
exactly we designed it to go 13 inches to be sure it would clear the foot mark
Unread 23-01-2007, 18:23
Madison's Avatar
FRC #0488 (Xbot)
We've been looking into honeycomb aluminum for some of the surfaces on our machine as well, but we've not had much luck finding local suppliers. We'd like to take a small sheet and put it through its paces first before committing to its use. We have some concern about how rigid it'll remain over long spans.
20 lbs. per side seems about right, given everything that's involved. It's a fantastic system for teams that really want to focus on scoring bonus points at the end of the match because of the many benefits it has over most ramp designs -- primarily, ease of use by partner robots. I'm interested to see more of what you've decided to use in place of this design.
--Madison--
Unread 23-01-2007, 18:40
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
two years ago, we used honeycomb aluminum for the base and type of honeycomb plastic for the sides, last year, we used honeycomb for to mount electronics on, and both years, it stood up to time.
we also have a 1 inch thick piece about 4*4 inches and people have been jumping on it, throwing it trying to bend since we got it at the beginning of the season and nothing, except for being a little squished in the corners, has happened to it.
we're also thinking of using a new type of honeycomb this year for our frame, but we're arent exactly sure yet
Unread 24-01-2007, 23:31
As I was looking at your model, I knoticed that at the position when the ramp is at its max, the piston is pulling dirrectly vertical. When it is in this position, the force from the piston is not able to prevent the ramp from going back down a little ways until the piston has a better pull angle. I think that you would have better luck if the piston was pulling at a slight angle when the ramp is fully up, or you figured out some other way to prevent this from happening.
Unread 24-01-2007, 23:46
Ha, we've got out 12" ramps down to 15 pounds for both sides.
Thank god for composites.
pic: Fallbot prototype amos229 Extra Discussion 5 05-09-2006 22:02
pic: 1251 Prototype v 1.2 David Guzman Extra Discussion 28 16-01-2006 12:14
Got an question on start postion of the robot? DanTheRobotMan Rules/Strategy 9 12-01-2006 17:32
pic: 35 MPH Prototype Crebb Robot Showcase 31 31-03-2005 16:02
