Thread Tools |
Rating:
Display Modes |
#18
Re: PID How to hold an arm in a fixed position without a locking gear box
Keep in mind that when you need high-torque motors (like in a programmed non-back drive mode), it helps to use two of them, if possible. If you wire the two motors together (+ to + - to -, then the combined + and - to the victor controlling them), now you are taking two circuits and combining them into one, distributing the power evenly. Not only will the two motors operate in perfect harmony, it will also multiply your torque and stall rating by two.
| PID without a Ph.D. | Joe Johnson | Programming | 3 | 07-02-2006 17:37 |
| Drive Straight C Code using Encoders without PID? | Chris_Elston | Programming | 17 | 15-02-2005 23:41 |
| White Paper Discuss: Locking the Bosch 3360 Drill in low gear | CD47-Bot | Extra Discussion | 4 | 05-08-2003 02:10 |
| how do you hold pins in? | archiver | 2001 | 4 | 23-06-2002 23:45 |
| How do teams hold their brainstorming meetings? | Anton Abaya | General Forum | 10 | 03-01-2002 18:02 |
