Go to Post I just think that if we are going to have rules intended to level the playing field, they shouldn't hurt teams that put the effort in to go the extra mile. - Dave Scheck [more]
Unread 23-01-2007, 21:51
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Re: Why Static Variables?
Originally Posted by brianafischer View Post
I am trying to create a list of "good" programming practices for the students. I cannot seem to google a good reason for proper use of static variables instead of globals. Anyone interested in sharing some knowledge?
When is a static variable required over a global?
What are the advantages of static variables?
What are the disadvantages of static variables?
Thanks!
There might be something that I'm forgetting, but I believe that the only advantage of static variables over globals is that a static variable is self-explanatory in the fact that it will only be used in that function. A global variable could be changed in other functions and someone reading your code would not know whether or not it is. If you are familiar with classes (in C++ for example), this is basically the same advantage as using private variables over public variables. I hope this was helpful, and good luck...
Static Cling?? orelinde Electrical 17 27-02-2006 17:33
Static Variables amateurrobotguy Programming 8 04-03-2005 00:40
Static Electricity JeffO Championship Event 5 19-04-2004 11:04
Static on the HDPE Al Skierkiewicz Technical Discussion 60 12-03-2003 17:52
Static Electricity archiver 2001 12 24-06-2002 00:34
