Thread Tools |
Rating:
Display Modes |
#23
Re: PID How to hold an arm in a fixed position without a locking gear box
I thought so too, and was about to respond saying so, but I couldn't locate the relevant rule to quote. Can you help me find what I'm certain I'm overlooking? So far, I haven't seen anything in the manual that says each Victor can connect to only one motor. The closest is <R98> which limits Spike relay modules to a single motor. <R91> restricts things in the other direction: "Each motor, actuator, and compressor must be connected to one, and only one, speed controller or relay module." But it doesn't say you can't connect multiple motors to the same speed controller.
| PID without a Ph.D. | Joe Johnson | Programming | 3 | 07-02-2006 17:37 |
| Drive Straight C Code using Encoders without PID? | Chris_Elston | Programming | 17 | 15-02-2005 23:41 |
| White Paper Discuss: Locking the Bosch 3360 Drill in low gear | CD47-Bot | Extra Discussion | 4 | 05-08-2003 02:10 |
| how do you hold pins in? | archiver | 2001 | 4 | 23-06-2002 23:45 |
| How do teams hold their brainstorming meetings? | Anton Abaya | General Forum | 10 | 03-01-2002 18:02 |
