Has anyone keyed IFI wheels instead of using the bearings?
I need to find a simple way to key the ifi wheels to the drive shaft.
any insight(words, pictures, inventor files) would be much appreciated -matt |
Re: Has anyone keyed IFI wheels instead of using the bearings?
The AM universal hubs linked above have an identical bolt-hole pattern to the one on the IFI traction wheels that is typically used for a sprocket. They are also really, really light...
-Dillon Compton |
You other option being to lathe and broach something similar to the AM one, but use the bolt holes for the bearing retainers instead of the ones for the sprockets.
| TO much traction??? (ifi wheels or AM wheels) | Heretic121 | Technical Discussion | 9 | 04-02-2006 12:09 |
| Using the IFI loader with a USB-to-serial adapter? | Eldarion | Programming | 7 | 26-01-2006 23:33 |
| omni wheel instead of mecanum wheels | Leav | Technical Discussion | 4 | 15-01-2006 18:53 |
| has anyone ordered the wheelchair wheels outside of skyway? | archiver | 2001 | 0 | 23-06-2002 23:17 |
| Skyway wheels w/o bearings | ahecht | Technical Discussion | 4 | 22-01-2002 01:25 |
