Go to Post AndyMark is proud to announce that we will now be offering banana same-day shipping during build season for those food-deprived students on your team. - Hitchhiker 42 [more]
Unread 10-01-2007, 18:59
IfIwasarichman IfIwasarichman is offline
None #1566
IfIwasarichman is an unknown quantity at this point
Suction Cup Nut
Does anyone know what size of a nut will fit the outside threads of the suction cup device included in the 2007 parts kit and is it metric or standard?
Unread 10-01-2007, 22:23
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Suction Cup Nut
It's printed on the spec sheet that came with the suction cup.
Sorry I don't have it with me, or I'de read it off for you.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 23-01-2007, 21:20
mcmouse mcmouse is offline
FRC #0451
mcmouse is an unknown quantity at this point
G3/8" tab - Suction Cup Nut
we bought a G3/8' tab
and will make our own G3/8" female nut to mount suction cups
this is a very special thread BSPP and was nowhere to find.
If anybody needs nuts, we could supply those for a small fee (material) and shipping reimbursement. jens
Unread 24-01-2007, 07:44
None #0612
Re: Suction Cup Nut
We bought these nuts at the local hardware store. They are brass compression fitting nuts for plumbing pipes. ANy plumbing supply store carrys them. Just bring the suction cup in and ask them to match the threads.
Unread 30-01-2007, 22:09
NHPilot NHPilot is offline
NHPilot is an unknown quantity at this point
Re: Suction Cup Nut
Pretty sure it's M16x1.5. That's 16mm diameter X 1.5mm thread pitch.
Unread 31-01-2007, 08:21
FRC #0451
Re: Suction Cup Nut
the thread is detailed on the spec sheet : G 3/8"
but you have to dig thru the web to find out it stands for G= BSPP
(BSPP) - British Standard Pipe (Parallel) Threads
for G3/8 - Threads Per Inch- 19 (!)
see e.g. http://www.jwwinco.com/technical/bsp.htm
anyway we bought a special tab to "home make' nuts - they fitt perfect and work great. we could send you some, let me know. :-) JS
pic: how not to use a suction cup Sterno Chit-Chat 28 11-02-2007 17:00
Suction Device Rob2713g Technical Discussion 16 01-06-2006 17:29
Suction ????? ak_Knight Rules/Strategy 2 24-02-2004 01:57
2 Hours Sleep and I cannot bear to see another nut or bolt.. archiver 2001 2 24-06-2002 00:54
Lead Screw Nut archiver 2000 1 23-06-2002 22:49
