Go to Post When it all comes down to it, it's not gonna be the medal around your neck that makes the difference, but the memories that you think about when you look back on how you got there that makes the difference. - Beth Sweet [more]
Unread 23-01-2007, 08:50
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Backup onboard charger not correct
Originally Posted by dcbrown View Post
I wonder if just adding a switch into the circuit at the 12v + point would violate R56. At least then we'd have a manual method of disabling the circuit rather than physically unwiring it if there were issues we wanted to isolate.
As currently written, it would appear that adding a switch would be a violation of R56 though.
Bud
You can switch the power (12v) with a spike. Then when the robot is shut down, the charger is off. Drain to the backup battery in this case would be through r3/r2, about 5ma.
Unread 23-01-2007, 09:43
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Excellent idea. I'm sure there is spike already in the mix somewhere that is on if not on all the time, then most the time. The better idea would be a steering diode below the 'batt' point in the schematic... but the schematic isn't likely to change at this point so the spike at least addresses 1/2 the discharge/back power issue with the current charger design.
thanks!
Unread 23-01-2007, 22:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Paul,
If you use the IFI charging circuit, then IFI makes it mandatory to use it as it is drawn with no mods. If the RC should fail and they determine the cause relates to backup battery it may void the warranty.
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with the provided 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc.
There is no other provision beyond these two.
Where in the rules or on Innovation First does it say that we cannot modify this circuit to work the way we need it to work? I found nothing so we took it as a chance and modified it a bit. Added a steering diode to prevent the back feed, and we are going to add a 1 AMP fuse to it as well.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 23-01-2007, 22:57
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The general feeling around here about <R56> is that the backup battery may only be charged by the circuit from IFI, and not from a custom circuit. I could have sworn there was a Q&A that backed up this interpretation, but I'm not seeing it under section 8.3.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-01-2007, 23:10
RyanN's Avatar
RyanN
Maybe this will be clarified in Team Update #6 . I have 2 things that I'm not sure about, this, and the radio problem.
Controls Mentor
@rnazaretian
Previous teams:
Unread 24-01-2007, 07:58
Ryan,
I could see how it might be interpreted that way but the rules simply state the IFI suppied circuit design must be used. I read that (and the inspectors last year were interpreting it) that it is and must remain unmodified.
Unread 24-01-2007, 08:06
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
The rules say:
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with the provided 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
This rule does not say that it MUST be charged with the IFI circuit. This wording appears to allow an alternate, on-robot charger. We should get an official ruling from USFIRST on this.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 24-01-2007, 08:17
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I have already submitted a Q&A to the official FIRST forums. We should have our answer in a few days.
Unread 24-01-2007, 08:18
The rules say:
Jerry,
Read that rule as "if you charge it on the robot it must use the IFI charger. If you charge it off the robot then you must use the supplied charger". There is no other alternative.
Unread 24-01-2007, 08:34
None #0612
Certainly that is the safest way to read the rule, but USFIRST has in the past been very specific in their choice between the words "may" and "must". If this rule specifically, definitively, was intended to disallow an alternate on-robot charger, is should use the word "must".
A poorly designed charger could lead to overheating of the batteries, so a specific charger design should be used here.
I'll be interested in their comments on this.
Unread 24-01-2007, 08:46
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
I might be wrong...
I am assuming they are enforcing the use of the IFI circuit for safety reasons, but if they truely want to be safe, they should include something prebuilt in the kit because there is no guarantee that whoever builds the circuit will build it correctly.
Unread 24-01-2007, 09:26
We have just built one, and will post some voltage and current measurements in the next few days.
I would not be concerned about overcharging, the current is limited by the resistors, it is only on for a few minutes at a time, and you should only be using this circuit if you have servos & cameras drawing power.
Unread 24-01-2007, 09:41
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
We might be getting a new schematic... I can't find it on the IFI web site.
Unread 24-01-2007, 23:36
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
Second that. The links in this thread are 404ing.
Unread 24-01-2007, 23:44
RyanN's Avatar
RyanN
Oh geez... right after I built the old defective one .
Controls Mentor
@rnazaretian
Previous teams:
Stamp is probably not releasing a new version this week. buss Scouting 1 29-03-2006 22:10
STAMP version 1.0 (NOT BETA) is out for week 1! Ethulin Scouting 5 01-03-2006 18:50
Rookies, wish you knew that earlier? Erin Rapacki General Forum 0 24-02-2005 11:49
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Onboard Camera? XRaVeNX General Forum 18 03-02-2003 20:28
