Go to Post A good defense can defend against a good defense. - Squeakypig [more]
Unread 21-01-2007, 09:45
Smoking_Gun Smoking_Gun is offline
AKA: Tal
FRC #1943 (Neat-Team)
Smoking_Gun is an unknown quantity at this point
Accelerometer Code
I’m having trouble finding the accelerometer’s code for this year or last year’s Accelerometer.
Can someone tell me where it is?
Thanks, Tal
Unread 21-01-2007, 15:35
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Accelerometer Code
Thanks, Tal
I don't know about the Code for the EasyC.
If you need it for the regular C then go here->2005 FRC code Repository
It's somewhat old but you should be able to modify it. It has the full ADC code built it but it would be better if you take Kevin Watson's ADC(new one not the 2005 one) code and integrate into it, this way you can use other analog sensors simultaneously.
Unread 24-01-2007, 08:33
AKA: Tal
Thanks. I tried to work on this code but I don't know how to change it to work with dual-axis accelerometer (last year is dual-axis, but 2005 has only one axis...).
Can someone help us by publishing the accelerometer code that is modified to work with the dual-axis accelerometer?
P.S.
Kevin said last year that he will publish the code, but I can't seem to find it either.
Thank you for your help.
Tal, Neat-Team
Unread 24-01-2007, 09:09
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
JFYI: easyC has the code built in.
Unread 24-01-2007, 10:41
Kevin Watson's Avatar
La Cañada High School
FRC #2429
P.S.
If you're trying to use the sensor to measure tilt relative to the gravity vector, just use the ADC code to measure the outputs. Remember to take into account the ~2.5 volt bias. I have some code floating around here somewhere that shows how to derive tilt from the two outputs. I'll have a look and post what I've got.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-01-2007, 10:54
FRC #2429
-Kevin
Have a look at the attached code. You'll also need to get a copy of the ADC code from my website.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-01-2007, 13:57
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
If you'd like, I also developed some code for using the accelerometer (for tip sensing or for position/velocity sensing). The code can be found in my old post here:
http://www.chiefdelphi.com/forums/sh...82&postcount=5
It works with Kevin's 2006 ADC code so you can use it with other analog sensors. I'm currently working on modifying it to support dual and triple axis accelerometers for our robot this year, I'll post up the new versions when I have them finished.
Does anyone has code for accelerometer? sjung9442 Programming 2 30-01-2006 21:37
Accelerometer code?! David55 Programming 2 25-01-2006 01:15
Accelerometer code ImmortalAres Programming 28 04-06-2005 01:02
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
