Go to Post WATER GAME! Always a water game... - kendra21093 [more]
Unread 24-01-2007, 10:27
Andrew1742 Andrew1742 is offline
FRC #1742
Andrew1742 is an unknown quantity at this point
Ramp alternatives?
I've heard and seen alot of discussion about ramps. This is an obvious solution for the endgame, but I was just wondering if anyone out there is using a lift system instead of ramps? Or any other method?
Unread 24-01-2007, 10:33
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: Ramp alternatives?
http://www.chiefdelphi.com/forums/sh...ht=Lift+system
There have been many discussions about Lifts v. Ramps
Min-Max to the Max!
Unread 24-01-2007, 19:16
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
Hoverbots, of course!!
(Sorry I just had to)
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 24-01-2007, 19:19
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
but whats going to power it after the match is over?
Unread 24-01-2007, 20:44
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
A lift could be kept up after ower is turned off if it is a pneumatic piston on a dual action solenoid. These solenoids have three positions: extend (fwd = 1, rev = 0), middle(fwd = 0, rev = 0), which doesn't change the current state, and reverse(fwd = 0, rev = 1). Turning off the bot should only put the fwd and rev to zero, leaving an extended lift extended and judgable.
Unread 25-01-2007, 10:24
FRC #1742
But would the robot have to be turned back on to get the other robots off the field?
Unread 25-01-2007, 10:33
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
That is what humans are for. Besides, once a bot is lifted, it is easier for humans to pick it up.
In the past, robots have never been powered back on to get them off the field. Take it to the pit and restore it to it's original configuration.
CMUcam2 alternatives? groves Technical Discussion 6 10-01-2007 10:09
3ds max alternatives? Mazin 3D Animation and Competition 24 11-11-2006 19:43
Gear alternatives Booger Technical Discussion 6 23-07-2006 02:27
USB-to-Serial Interface Alternatives Josh Adelson FIRST Tech Challenge 8 22-03-2006 09:40
VEX Alternatives... 114gopher FIRST Tech Challenge 3 24-04-2005 20:02
