Go to Post Public Service Announcement: Pressing the spacebar when the robot is enabled isn't nearly as funny the forty-second time. - Taylor [more]
Unread 24-01-2007, 10:40
Electrical Engineer
Rookie Year: 1995
Re: How the GTS works?
Originally Posted by Bomberofdoom View Post
I am trying to understand how the GTS/Accelometer works. If the GTS has counted one tick what distance came through, or who much degrees is one tick?
Thanks.
The GTS is a Hall Effect gear tooth sensor. It senses "ticks" when a gear tooth passes near to the sensor. The size of the gear onto which the sensor is mounted, the gear ratio between that gear and the wheel and the diameter of the wheel are all specific to your design.
As to angle: If you have mounted the GTS next to a 60 tooth gear, the angular resolution is 6 degrees per tick.
Regards,
Mike
Mike Betts
As easy as 355/113...
GTS Code Error (the red light of doom!) Denz Programming 9 07-04-2006 17:39
Where are the new sensors(2AA, YRG, GTS)?? Doug G Electrical 5 08-01-2006 21:50
We're on How Stuff Works?!? Redneck Chit-Chat 1 29-09-2005 18:32
How FIRST Works on howstuffworks.com Elgin Clock General Forum 2 15-05-2005 02:17
How Stuff Works: Segway Jnadke Dean Kamen's Inventions 3 17-07-2002 16:55
