Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Unread 24-01-2007, 14:01
Re: Team Communications
Originally Posted by wrenauld View Post
The rules regarding communications does not mention anything about hand signals from the team members sitting in the stands. It it legal to use some sort of hand or graphic signals to communicate with the operators?
In addition to the other posts, keep in mind that the venues will all have artificial lighting over the playing field and frequently the audience area is unlit or far away. For those reasons, no one can expect to communicate reliably to players on the field. In a two minute match, why would you break your concentration to look for a person in the stands and then to interpret what the signal might be. It just isn't practical.
Serial Communications 6600gt Programming 14 28-06-2006 23:24
Spotty Radio Communications! Mr. Lim Control System 12 22-02-2005 20:47
Timer 0/Serial Communications? steven114 Programming 2 13-02-2005 20:50
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Radio Communications... Dan 550 General Forum 9 29-12-2001 17:00
