Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 24-01-2007, 14:57
Tangello_angela Tangello_angela is offline
FRC #1676 (Pascack Pi-oneers)
Team Role: Electrical
Tangello_angela is an unknown quantity at this point
Send a message via AIM to Tangello_angela
tilt/pan away
What should i do if when try to track the light with the CMU cam, in the LabView GUI app, the camera find and tracks the light but instead of moving towards the light it moves away?
If the camera is mounted normally the tilt is messed up. If we mount it upside down the pan gets messed up.
Unread 24-01-2007, 15:25
Re: tilt/pan away
I don't understand what you're trying to do. You can't use the LabView application to track the target light. The tracking software runs on the Robot Controller.
If you're using the marvelous code from Kevin Watson, there are macros which define the pan and tilt directions. Change the sign of the appropriate one to make the camera seek instead of avoid the light. (I don't know enough about the EasyC function to tell you what to change in it.)
Unread 24-01-2007, 15:43
chapmatr's Avatar
chapmatr chapmatr is offline
Zippidy bling-zap whippy-wog snizin
AKA: Travis (Lead Programmer)
FRC #1676 (Pascack Pioneers)
Team Role: Driver
chapmatr is an unknown quantity at this point
Send a message via AIM to chapmatr
Re: tilt/pan away
? We have the labview CMUcam2 GUI. The program tracks the light, but gives the servo a negative value, so it tilts away from the light, then even more, because the image is "upside down." Pan is fine though.
Did you know that 87% of all online statiscs are made up?
Unread 24-01-2007, 16:07
Cynix Cynix is offline
FRC #0074
Cynix is an unknown quantity at this point
Re: tilt/pan away
If you're using Kevin Watson's tracking code look in tracking.h and find
#define TILT_ROTATION_SIGN_DEFAULT
That will be set to either 1 or -1, if your pan is tracking the wrong way try switching the value. If you mount the camera the other way you may need to adjust the pan rotation sign also/instead.
Unread 24-01-2007, 16:20
Re: tilt/pan away
Are you using last year's camera? The 05/06 version of the CMUCam2 had servo control headers on it. When the camera was in "tracking" mode, it would compute the output values needed to center its vision on a particular color blob. Kevin's camera tracking code (servos controlled on RC, NOT CmuCam) simply tricks the CMUCam into thinking it is controlling the servos. The software on the CMUCam constantly updates these servo values and spits them out to the headers. This is why your camera will track when using the LabView App.
This year's camera does not have on board servo headers. With the addition of the illuminated target, there is really no good reason to use the LabView app, except to see what the camera is processing.
Why use the RC to control Pan/Tilt Joe Hershberger Programming 15 30-01-2007 23:41
pan/tilt connection for 2007 camera kasemodz Programming 5 21-01-2007 14:21
Question about pan/tilt itsme Programming 1 12-01-2007 10:49
pan & tilt errors itzrobz Programming 2 19-02-2006 19:12
CMUCam pan and tilt sheyna Programming 9 14-01-2006 23:20
