Go to Post Not all creativity is visible or mechanical! - dtengineering [more]
Unread 23-01-2007, 20:24
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
stdarg.h Syntax error
Hello,
This is my first time posting here, and first year compteting! I'm excited to be here, and thought that was worth mentioning
My problem, as that out of the blue my compiler gives me the error
Stdarg.h:6: Syntax Error
The line is
typedef void* va_list;
I have no idea why this occured, as about a hour earlier it compiled fine, and the only change I had made to it was adding a printf() statement. I tried deleting that afterward in hope that was the problem (though it shouldn't be anyways), but no go. The error was still apparent.
Has anyone encountered this before, or have any solutions?
Thanks a bunch,
Jedd
Unread 23-01-2007, 20:33
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Re: stdarg.h Syntax error
I have a hunch that you messed something up near the beginning of the file, and the stdarg.h error is simply the compiler complaining as a result of something in your file. For example:
int foo = 6 // no semicolon!
#include <stdio.h>
will tend to give you an error in stdio.h, even though the problem is in the original file. Take a look at the top of your file for syntax errors.
Unread 24-01-2007, 15:50
All right, thanks. I don't think that is the problem as I've only added one function and the printf() function to all the code, and the function I made worked properly the day before... I'll check again. Anyne by chance know what file stdarg.h is included in?
Unread 24-01-2007, 16:17
stdarg.h is included by stdio.h
It is simply the first true line of code the compiler encounters when #include <stdio.h> is used and it can recognize that an error has occurred. The error won't be in the system files, but in .c files you have touched.
Usually I've seen this when random characters are accidentally typed on the very first line of a .c file.
Take a look to see if anything has been typed BEFORE the
on the very top line of the .c files you've been modifying.
Unread 24-01-2007, 16:27
That was it! Thanks... I didn't find in the files I had been in, so I went through the others, and behold, there was a random "v" as the first character of the file.
Thanks a bunch for your help!
Jedd
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Array Syntax Error Andrew Blair Programming 7 05-02-2006 14:11
Syntax Error! Denz Programming 15 04-02-2006 23:57
Simple Syntax Error miketwalker Programming 6 06-01-2004 00:17
