Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 23-01-2007, 20:37
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Will you be running a bumper?
I mostly read the forums and rarely write, but I've been thinking about this for the last couple of days, so here goes.
Is your robot going to run bumpers?
This seems like an important question because there will be a lot of variations of ramps and lifts, and since the bumpers increase the width of the robot and also reduces the ground clearance, the ability for the robots to get on these ramps and lift may be limited.
Any thoughts?
Unread 24-01-2007, 00:44
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Will you be running a bumper?
Yes, we're using bumpers. Biggest reason is the free 15 lbs of extra weight. Our robot is a ramper which we have designed wide enough to accomodate robots with bumpers. With all the ramps deployed we're almost 10ft wide, We have enough parking space 12 inches above the carpet for two bots with or without bumpers. Btw our ramps aren't just for parking robots on.
Unread 24-01-2007, 00:50
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
Our team will use bumpers for the protection, part of our robot last year got trashed b*c we got rammed hard and we couldnt put a bumper there....also you might think about making this into a poll
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
Unread 24-01-2007, 01:46
AdamHeard's Avatar
Lead Mentor
We built a pretty durable base but we are still running bumpers for looks, for weight, and for durability.
Unread 24-01-2007, 10:26
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
You rarely post? (first post). Hehe
Bumpers add the 15lbs which is why many teams put them on. Last year we didnt put them on because our robot was strongly built and didnt need protection. We talked about putting them on but we havnt reached a decision.
Min-Max to the Max!
Unread 24-01-2007, 11:19
We will be using bumpers. I watched too many robots last year climb onto the wheels of robots that looked similar to what we are building this year and effectively disable them. I also don't like the idea of having our cantalevered wheels so exposed. We are adding bumpers to prevent that problem. It also adds 15 pounds, and who can say no to that!
To have our bumpers mounted legally, we need to have them 1/2 of an inch above the bottom of our frame. We are using 6 inch wheels with a 1x2 tube stock frame. They shouldn't limit what we can climb, unless the ramp is steep enough that we get our bumpers stuck on it before our wheels get on the ramp and start climbing.
Unread 24-01-2007, 11:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
No bumpers here.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-01-2007, 15:59
Choi9111's Avatar
Choi9111 Choi9111 is offline
(^_^)v I ROCK!!!!
AKA: BAKA!!!!!!!!!!!!!!!! (Tomo) >_<
FRC #0932 (Leviathan)
Team Role: Driver
Choi9111 is on a distinguished road
I think our team is going without bumpers. i guess it all depends on the robot design and the way you use your robot.(defensive i.e. ram/block)
I AM Leviathan...only not as green and slimy...and i only have 4 limbs not 8...wait technically im not leviathan at all...>_<,
Unread 24-01-2007, 16:22
Nate Edwards Nate Edwards is offline
SWARM Head Mentor
FRC #0957 (SWARM)
Nate Edwards will become famous soon enough
How many sections of ramp will you have and what angle of ramp? Which position to do you have to be to be entirely in the home zone (Ie, which way do robots come up to your ramps? How could you use ramps in the rest of the match without violating the wedge rule?
South West Albany Robot Mechanics
2002 Pacific NW Regional Rookie All Star Award Winners
2003 Pacific NW Regional Daimler Chrysler Team Spirit Award Winners
2004 Pacific NW Regional Johnson & Johnson Sportsmanship Award Winners
2004 Pacific NW Regional Winning Alliance (492 (#1 Seed), 1031, 957)
2003 & 2005 Pacific NW Regional Chairman's Award Winners
2009 Oregon Regional Woodie Flowers Award Winner
Unread 24-01-2007, 16:30
My guess is that they will not deploy the ramps until the end game. At that point, they will be in the home zone and deploy the ramps, then wait for their partners to come up them.
Unread 24-01-2007, 16:34
SWARM Head Mentor
FRC #0957 (SWARM)
I was writing in regard to the end of the post about using the ramps for more then parking robots on. I also had a question about the end Tape (the 2 inches) is that at the end of the 8 feet box or inside the 8 feet box.
You are not allowed to touch outside the home zone (even by an inch) when deploying larger then 72 by 72 correct? (this is for the bottom robot with the ramp, its not clearly defined in the rules, but the tape is considered in the zone.
Unread 24-01-2007, 16:35
AKA: Alvin
FRC #1967
[quote=65_Xero_Huskie;564123]You rarely post? (first post). Hehe
QUOTE]
Heh, I had a different ID and password back in 99 as a student on 192 (Gunn). I was the operator of the arm which caused quite a bit of controversey (there were gyros, broken bots, and DQs involved). But most of you are too young to remember that =P I've gotten back into the game as a mentor on 581 last year, and this year mentoring both 581 and 668. Also helped with the Calgames last year and probably this year.
Alvin
Unread 24-01-2007, 16:40
Not allowed to be outside the HZ, but I'm not sure whether that includes the tape or not.
And using the ramps for more than parking robots on--I'm not sure what that team is up to (other than blocking off a few tubes, maybe?), but I'd suggest that they make dead sure it's legal. If there's any doubt, they should ask Q&A if someone hasn't already.
Unread 29-01-2007, 22:29
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
I think bumpers are really useful.
if your in offensive bot, it gives you protection from bots paying defense
if your defensive it gives you protection and added weight.
1568 will most likely be using bumpers this year.
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 29-01-2007, 22:33
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Yep. We are indeed using bumpers. Wider base, more weight down low, and a wonderful place to stick some team numbers.
And for the one who asked on which side of the 8ft mark is the tape. The tape is on the inside of that. I remember measuring to the side close to the player's station, reading 7'10" and thinking "that's an odd number".
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
What row will you score on or will you score at all? rarprrydude234 Rules/Strategy 28 29-01-2007 17:55
Will camera keep running if i have a while statement going NextPerception Programming 13 08-02-2006 21:53
Did you make friends at a regional.. but dont know if you will ever see them again? Ashley Christine General Forum 66 10-04-2005 17:25
Which will you be watching? SuperJake Chit-Chat 25 25-01-2003 11:56
And when you wake up, you will think I am the sexiest man alive.... Joe Matt Regional Competitions 14 21-03-2002 22:17
