Go to Post Ahhh. The Grammar Fairy strikes again! - Cynette [more]
Unread 24-01-2007, 21:33
skrew-ball skrew-ball is offline
None #0975
skrew-ball will become famous soon enough
Re: FRC: Reset and Program Controls
I am pretty much new to the electronics, but I'm putting a button and toggle system for this to work. First the ground runs to the button, then from the button to the common pin of the toggle. From the toggle it finishes it's loop to the pin outs. This will work by only completing the circuit when the button is pressed on the desired toggle side. Making it plug in next to the cables allows for a quick plug-in and setting in a simple place ment.
Code runs only once, fails on reset roknjohn Programming 7 21-02-2005 20:24
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
