Go to Post People don't have to "get" it. They just have to know about it. Once they know about it, then they come to it, experience it, talk to it, learn it, then get it. - Taylor [more]
Unread 04-02-2006, 12:01
yanksrock777 yanksrock777 is offline
FRC #1468 (J-Birds)
yanksrock777 is an unknown quantity at this point
Send a message via AIM to yanksrock777
FRC: Reset and Program Controls
My team is having some troubles with the electrical layouts and we want to make things much easier for the programmers. We were thinking of creating a switch for the reset and program buttons on the FRC controller. There is a three pin port where is says Reset/Prog. I was wondering if we could create a switch for the reset and program buttons instead of having to press them directly on the board. If that is possible than how would I wire the push buttons switches to the pins? Does anybody have a schematic? Thanks
Unread 04-02-2006, 12:45
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: FRC: Reset and Program Controls
Yes, you can. Directions are found right on the Innovation First website under Robot Controller Reference Guide, page 13.
http://www.ifirobotics.com/docs/rc-r...01-31-2005.pdf
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 04-02-2006, 18:03
You can make things very easy on the programmers by extending the switches all the way to the PC they're using. The program port only uses five of the available nine pins in a serial cable. We "stole" three of them with a little adapter at each end of the cable, putting a reset and program switch right at the programmer's fingertips.
Unread 24-01-2007, 21:33
skrew-ball skrew-ball is offline
None #0975
skrew-ball will become famous soon enough
I am pretty much new to the electronics, but I'm putting a button and toggle system for this to work. First the ground runs to the button, then from the button to the common pin of the toggle. From the toggle it finishes it's loop to the pin outs. This will work by only completing the circuit when the button is pressed on the desired toggle side. Making it plug in next to the cables allows for a quick plug-in and setting in a simple place ment.
Unread 24-01-2007, 22:37
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
That's an excelent idea! I think I'll build a similar setup for our team. For the curious, take a look at the "program-port-y-cable.pdf" and "program-port-4-7-05.pdf" files on the IFI site (I don't have exact links off hand, just my downloaded copies). You'll see that the following pins are used: 2,3,5,7,8 (5 is ground). If anyone else makes a simlar setup, make sure that the wires you "steal" are not those pins.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Code runs only once, fails on reset roknjohn Programming 7 21-02-2005 20:24
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
