Go to Post Just because you haven't witnessed parts leaving the flywheel yet, doesn't mean it won't happen. - Al Skierkiewicz [more]
Unread 23-01-2007, 00:20
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Weight? Estmate weight?
Jenny Crage for robots anyone? I know it's a bit early to ask, but who here is feeling they are headed down that over weight route? Or are you carefully planning out everything? So far our bot is 70 lbs underweight, hopefully that stays around there, and all we will need to worry about is buying chunks of lead.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 23-01-2007, 01:49
dtengineering's Avatar
AKA: Jason Brett
Re: Weight? Estmate weight?
Yeah... ours is about there too... but we've still got to add the motors, electronics, gearboxes, wheels, chassis, lift, arm, ramp, flag holder...
Nah. We're doing okay. After having to shave twenty pounds in the last week of build two years ago we try to stay on top of things. Just everyone remember to leave a pound or two for repairs at regionals. We started GTR at 118.5 and entered the playoffs at 120.0 last year after some mid-Friday repairs.
Jason
Unread 23-01-2007, 08:57
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Weight seems to be an enemy more so due to the class system.
I had the nice notion this year of planning weight. (Keyword is had...)
We weighed all the parts, did some serious guestimation on some others. They wrote it all down and I started putting it in an Excel Spreadsheet in Openoffice. The idea was to drag and drop parts into a list and have a reasonable weight window for the robot.
I was down to the Electronics when something happened and I lost two hours of data entry. I have not had time to sit down and put it back into Excel but that is probably something I'll do tonight.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 23-01-2007, 10:28
Brian Mocci's Avatar
Brian Mocci Brian Mocci is offline
Still hanging around..
FRC #0195 (Cyber Knights)
Brian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to behold
Send a message via AIM to Brian Mocci
We've been planning on a 5foot frame, so 110 pound limit. Finished aluminum base weighs about 35-37 pounds with transmissions in. Add chain and wheels and we are at about 42lbs. This year we are making sure our arm team has enough to play with =P
UTC Regional Champions
2006
UTC Innovation And Control Award
Nationals Innovation and Control Award
Nationals Einstein Runner-Up
Unread 23-01-2007, 10:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're looking at close to 60 lbs for chassis/drivetrain, not including electronics or pneumatics.....leaving the arm team and ramp team very little to play with on a 110 lb robot!
which is a good thing if you look at it from the CG perspective.
Unread 23-01-2007, 11:20
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
We did a "full" CAD model this year for our robot, and according to the computer it weighs 94.4 pounds without electronics, chain, and fasteners. (hence the "full") But this is also coming from the computer that calculated our IFI wheels at 0.79 pounds each... so we'll see how it turns out. A word to the wise...when your doing your computer model... just keep in mind that fasteners can add a significant amount of weight.
A quick on CG though, you want to make sure you keep it lower than the distance between the center of your frame and the front or back drive wheels. This is usually somewhere around 10-15 inches depending on your wheel selection. If not...your robot may have some interesting driving characteristics...
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 23-01-2007, 11:56
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Well, right now our robot is only...maybe 10lbs?
Maybe we will gain more weight when we add more than just the wheels and control board.
I expect us to not be light this year (as in every other year before). I dont see the point in a light robot.
Min-Max to the Max!
Unread 24-01-2007, 21:10
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
our chassis, electronics. air compressor, 4 victors, 4 spikes, all the proper wireing,
Full drving robot as seen here: www.mmrambotics.ca
comes in at a smidge under 50 lbs without the battery.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 24-01-2007, 21:25
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
Let me put it this way. I think putting me on the field would weigh less than the robot we're planning. Can we just ditch a battery or a motor?
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 24-01-2007, 21:28
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
We made a custom chassis this year, and when we weighed it, it came to about 42lbs with electronics.
Unread 24-01-2007, 22:13
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We have an estimated weight of 98 pounds and I believe we're at 30-40... or something. That's just the chassis.
I think we're in pretty good shape.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-01-2007, 23:04
After finally inputing the correct weight of the CIMs and other motors into our model (Which caused a scare one night when I realized that the weight of the motors were ~3lbs total), we are at 103 lbs without ~4 lbs of chain. I feel much better about the robot's weight this year than last year, where we had to remove 10 lbs of weight on the Thursday of the competition. This should be the first year in my 4 years of FIRST where we add extra weight to the robot instead of frantically take it off.
Unread 27-01-2007, 20:32
Nick 1523's Avatar
Nick 1523 Nick 1523 is offline
Robot Manager
AKA: Nick Clark
FRC #1523 (M.A.R.S.)
Nick 1523 is an unknown quantity at this point
Send a message via AIM to Nick 1523
We've weighed all of the stock parts, frame, and used inventor to estimate weight. We're planning on using the smaller heavier config and weight is gonna be close but I think we'll make it. There's always the hole saw ! But i agree i would much rather add lead weights than end up making swiss cheese out of our bot.
Unread 27-01-2007, 20:35
Koko Ed's Avatar
Happy Birthday! Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We have a practically fully built robot and it's 82 pounds. We'll see how much weight adding a ramp will cause her weight to "ramp up" (couldn't resist. Sorry).
Unread 27-01-2007, 22:40
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
can we claim to have ours weighed according to the moons gravitational pull? it would really help us alot
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
WEIGHT?? Squeje250 Rumor Mill 9 14-02-2005 16:42
Weight Michael Leicht General Forum 43 16-01-2005 10:09
Weight Kojib Technical Discussion 9 01-04-2003 10:47
Weight??? candy12 Technical Discussion 1 16-02-2003 17:48
