Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 23-01-2007, 22:47
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Radio mounting position
I have read the manual, and I have asked numerous team members, and we have found nothing of this issue. Can we mount the radio in a position that the LEDs will not be visible? We want to mount it under our chassis to save some room and we think it will be just as safe under there.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-01-2007, 22:51
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: Radio mounting position
I was asking my self the same question. I never found anything it just said the LEDs on the rc need to be visible. So i guess yes you could mount it under there, but to be safe you could go to the First Q&A.
Unread 23-01-2007, 22:52
RyanN's Avatar
RyanN
Yea, that's where I'm going next. I just wanted to know what the Delphi community had to say.
Also, thanks for the speedy reply.
EDIT: Now I must wait for FIRST to authorize my account on FIRST Q&A.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 24-01-2007, 08:23
Never mount it underneath the chassis. Although there is no rule on this, experience tells us that the antenna should be mounted in the clear (but in a protected spot) and as far away from metal objects as is possible to insure good communication with the OI. The LEDs will tell you a lot about operation if you are having a problem.
Unread 24-01-2007, 23:42
RyanN's Avatar
RyanN
We were going to mount it upside down under the chassis and route the antenna through our electrical board so it still points up. We wouldn't be having the problem of placing the radio someplace this year, except the radios are more than twice as big as the old ones. Does anyone know the reason behind this? I have not seen any improvements or advantages that this monster has other than its easy to find .
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 24-01-2007, 23:48
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I HEARD the company making the physical radio changed, and I think since the old one was protected by copyright design laws, the design had to change enough to be functional, but look different.
idk.. That's just what I heard.
It could be for a variety of reasons, but that makes sense and if they did it to have it redesigned year to year.. why not make it smaller.. I think this was a last minute (so to speak) kinda design change.
But that's only speculation on my part which we all know is bad, but can't help doing it.
So.. meh.
Unread 25-01-2007, 08:00
Ryan,
That still places a lot of material in close proximity to the antenna which will detune it. Placing a critical component under the chassis still subjects it to the odd chance that it will be damaged when you roll over a part dropped by another robot. Protection is still a top priority of devices that will shut down the entire robot.
Which position is A vs. C MattB703 Rules/Strategy 3 29-03-2006 08:56
Starting Position jakey Rules/Strategy 2 08-01-2006 16:37
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
Starting position? Mark Garver General Forum 4 06-01-2003 07:45
