Go to Post If I was a balding man, and Dean Kamen signed MY head, I'd immediately make my way to the nearest tattoo parlor and have them make it a permanent fixture. I wouldn't have washed it off! Just saying. - Carolyn_Grace [more]
  #31   Spotlight this post!
Unread 25-01-2007, 00:12
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
Re: Backup onboard charger not correct
Built mine on monday, didnt have too much trouble with it, oh well, that's life. However I do hope that they manage to produce a new circuit for us, the idea is still great and I hope that they do generate another circuit.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
  #32   Spotlight this post!
Unread 25-01-2007, 14:49
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
does anybody have a working link to the pdf file for the backup charger? the one at http://www.ifirobotics.com/docs/firs...up-charger.pdf seems to be down
http://www.wcsrobotics.com
team 663
team 1493
  #33   Spotlight this post!
Unread 25-01-2007, 15:03
Keith,
As mentioned above, I agree that IFI may be rethinking the design. Be patient, I am sure they are working on something.
  #34   Spotlight this post!
Unread 25-01-2007, 15:09
FRC #1493 (Falcons)
whops! I must have skipped past that page by mistake, thanks for pointing me in the right direction.
team 663
team 1493
  #35   Spotlight this post!
Unread 25-01-2007, 17:35
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Modified schematic now posted on IFI: http://www.ifirobotics.com/docs/firs...up-charger.pdf
  #36   Spotlight this post!
Unread 25-01-2007, 18:03
It's the same schematic, with the 43 ohm resistor changed from 1 watt to 2 watt. No, wait, there is a difference: the RC is now connected to the output of the regulator. There still isn't anything to keep the backup battery from backfeeding the 12 volt input, though.
There are two cosmetic changes to the print. First, it's got color. Second, it says
Note: Use at your own risk,
Not supported by IFI.
So I guess we're not going to find out the official theory of operation any time soon.
  #37   Spotlight this post!
Unread 26-01-2007, 12:09
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
About the updated backup battery charger on IFI website:
Its better, the RC controller is connected right after the regulator now. The RC is still running off the 8.7V zener instead of the regulator though (although through the 43 ohm resistor). I think R1 could be removed. Let the battery charge off the output of the regulator. The Zener D2 could be left to protect the batery in case the regulator shorts outs. This would also take care of the discharge problem. when 12V is off.
I like how the manual highly recommends it, but IFI now says "use at your own risk".
Brian
Brian K
Team 1225 Robotics Mentor
  #38   Spotlight this post!
Unread 26-01-2007, 12:45
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Ok after reading through this thread I've noted a number of objections to the backup charger design from the EE types. However a few people have actually built and used the circuit with no terrible ill effects. The chief complaint seems to be that when the main power is turned off, the backup feeds back into the 12v circuitry. And if I am understanding correctly, this problem doesn't seem to be taken care of with the new design. Other complaints seem to be concerning the charge rate; in other words the voltage supplied to the backup is barely more than what a fully charged backup battery would produce.
Have I summarized correctly?
So, I am thinking that the puny charge rate is fine, as the only real purpose of this circuit is to reduce draw down of the backup battery when using the camera. Other loads are pretty minimal and of negligable concern during competition.
As for the back feed issue:
I believe the problem can be solved by introducing a switch that disconnects the backup from the RC when main power is removed. Best scenario would be to route the pigtail through a relay that disconnects the backup from the RC when main power is turned off. I don't think this is feasible with a Spike, so next best solution is a manual switch. Orrrr, just unplug the backup as part of the robot power down procedure!
  #39   Spotlight this post!
Unread 26-01-2007, 13:57
Circuit makes more sense now. We have not scrutinized the rules with this in mind, but I think it can and should get power through a breaker & spike.
I have one built, and will power it up and take some measurements soon.
  #40   Spotlight this post!
Unread 27-01-2007, 01:49
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
There should be enough EE types hanging around here to agree on an alternate backup charger design. Once there is a consensus we can at least offer the design to Ifi - if not for this year, then maybe next.
Attached is a straw design, let the darts fly. I purposely removed the values of most of the resistors to start.
Theory of Operation - abbreviated.
1. output voltage should be set to 8.5V, there will be a .2v(?) drop across the forward biased steering diode D1 presenting 8.3v to battery to be charged.
2. D1 prevents discharge when 12v is disconnected.
3. R1 provides a non-charging current to the backup battery input (100ma)
4. R2 provides charging current to backup battery (45ma)
5. D2 prevents the non-charging current available from R1 from mixing with or contributing to the charging of the backup battery
6. D3 is zener crow-bar to prevent voltage runaway due to the charger failing in some manner
7. D4 shunts any current spikes around LM chip to prevent failure.
8. Change C2 to 1uf
9. R2 and R3 selected per Vout = 1.25v * (1+R3/R2)
  #41   Spotlight this post!
Unread 27-01-2007, 10:57
Bud,
I think you are getting closer. I would make the input cap 500mfd and add a fuse or breaker to the input side. The diodes will have a 0.6 volt drop if you use standard 1n4xxx diodes. Since the output cap is very small the diode across the regulator is not needed but wouldn't hurt. It might be a good idea to make the diode in series with the backup a Schottky to gain an additional 0.2 volts of available power supply. If you add a diode in series with the charging reistor then the series resistor to the load is not needed. That way the diode in series with the battery will only conduct when the regulator drops out or goes below about 6.8 volts.
  #42   Spotlight this post!
Unread 27-01-2007, 12:37
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
OK, after much speculation (and a couple posts to Q&A) Update #6 clarifies the wording to match the interpretation that if you chose to use a charger on the robot, it must be the IFI provided circuit.
  #43   Spotlight this post!
Unread 28-01-2007, 10:57
AKA: Bud
Updated circuit as follows:
. selected 0.1% resistor values available from mouser.com that yeilds 8.5v
. use germanium diode (or small power transitor w/Vce of 0.3v) to block reverse current and drop voltage to 8.2v through charging resistor which has a C/16 trickle charge current target (45ma).
. use 1N4xxx diodes to drop voltage to 7.1v (or less, say down to 6.8v min), load current through R1 provides up to ~100ma of helper current if battery backup voltage drops due to extra load or loss of backup battery capacity.
. dropped steering diode between battery and R1 - shouldn't be needed on normal battery operation at 7.2v, but this new circuit will add charging current via R1 as battery voltage drops below 7.1v
. changed .1uf cap to 100uf on input. this is quite large for most regulators, shouldn't have to go bigger -- would need to see the charger circuit input at regulator in use with oscilliscope to determine if there were additional problems that would be addressed by larger capacitor.
Still not happy with diode selection, I'd almost rather swap out the germanium diode with a small power switching transistor that had a typical Vce of 0.3v - it should do the same thing as the diode, namely block discharge current when 12v battery not present.
User could add slow blow fuse into circuit as optional component in front of regulator. Say 250ma fuse. Another optional component would be a switch to disable the whole thing. Another optional component set would be a LED and series resistor at point in front of D1 to ground to show when circuit was active.
Looking for help on D1/D2 selection to achieve design voltages.... or someone to redesign the whole thing. Its easy to get carried away, for example I thought of using a 2nd LM317 in load support branch. It would be in constant current mode at 7.1v. This would current limit that branch more effectively but changes all the resistors and output voltage target of the first LM317. This would replace the D1/D1/R1 components. But goal of the design is to just be a basic/simple on-board charging circuit to prevent loss of voltage from the backup battery due to camera loading. The backup batteries main purpose is simply to prevent a brown out interrupt on the PICs which would result in processor resets.
1N4xxx diodes list Vf as 1.0v, but this is at maximum load. 1N58xx schottky diodes list Vf as .55-.6v range. Just need to get to a 1.4-1.5v drop across a couple diodes or transistors but don't know which would be best choice.
I'm looking to order some components with another order something in next day or two so I can breadboard and try this circuit out/take some measurements.
  #44   Spotlight this post!
Unread 28-01-2007, 18:41
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Where are you all buying the 1n5345 8.7V 5W zener? Digikey sell every 5W zener EXCEPT 8.7V
  #45   Spotlight this post!
Unread 28-01-2007, 19:21
http://www.mouser.com/search/refine.aspx?Ntt=1n5345
Stamp is probably not releasing a new version this week. buss Scouting 1 29-03-2006 22:10
STAMP version 1.0 (NOT BETA) is out for week 1! Ethulin Scouting 5 01-03-2006 18:50
Rookies, wish you knew that earlier? Erin Rapacki General Forum 0 24-02-2005 11:49
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Onboard Camera? XRaVeNX General Forum 18 03-02-2003 20:28
