Go to Post I don't think we really fit into those rigidly defined categories, my team builds our robot. - AdamHeard [more]
Unread 25-01-2007, 08:57
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Re: pic: Team 948 Shifting Transmission Version #2
Originally Posted by jfelser View Post
*bump*
Does anyone have thoughts on using a servo to drive this, without modifying the center spool to include a spring?
I pitty the little servo about to die. All joking aside, I think you might run into problems if there is no spring in the system. Remember for a short period of time every time you shift, there will be binding while you're waiting for the balls to line up with the slots in the gear. These transmissions are more friendly than others towards their shifting actuator, but I would seriously suggest having some spring in there. The plunger shaft doesn't have to have springs on it as long as the device actuating the plunger has some sort of shock absortion either in the unit or the connecting linkages.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 25-01-2007, 09:23
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
Yeah, after thinking about it for awhile this makes a lot of sense... mainly we are trying to get rid of the pneumatics weight - but, according to my calculations, we should be able to get 28 shifts each on 2 gearboxes before we run one tank down from 120 psi to 40 psi, so we may run our bot without a compressor onboard which would make this work.
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing jfelser Extra Discussion 24 18-12-2006 21:18
pic: Team 948 2 speed dog shifter adlai Extra Discussion 3 05-12-2006 07:54
pic: Concentric Shifting Transmission Concept Madison Technical Discussion 9 20-06-2006 21:49
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
