Re: Drawing or Model of Keyang Motor?
check www.firstcadlibrary.com under motors. It is listed as the "window motor" at the bottom. The hub for it is in the "Mechanical" section.
Can you confirm that the model on FIRSTCADlibrary is the same as the one in the kit this year? Thanks for the help, RAZ |
you could always pu thte motor in a mill to center find all the holes......if you have the resources that is...other that that, have you looked for a data sheet for the motor?
-John |
| 2 motor adapter and keyang motor dimensions | Bruno Estevão | General Forum | 1 | 16-02-2007 09:36 |
| Keyang Window Motor Gear pitch | AdamHeard | Technical Discussion | 3 | 19-01-2007 12:12 |
| 2 keyang motor to one spike? (was: need help..!!) | itay_ms | Technical Discussion | 2 | 17-01-2007 13:07 |
| 2003 Drill Motor Drawing | Joe P | Inventor | 4 | 14-05-2003 14:58 |
| Keyang Motor Thermal breaker. | archiver | 2000 | 1 | 24-06-2002 00:24 |
