Go to Post By "resources" do you mean money (sponsor or school), school support or permission, build facilities, or mentors? All of these require different solutions. - Carol [more]
Unread 25-01-2007, 09:31
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Drawing or Model of Keyang Motor?
Hello,
Does anyone have a drawing, CAD model, or even a spec for what the mounting pattern is on the Keyang motor? it seems similar ot some window motors used in past kits...
If anyone has this info and can post it I am sure there will be many grateful people in the CD community.
Thanks,
RAZ
Unread 25-01-2007, 10:21
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Re: Drawing or Model of Keyang Motor?
check www.firstcadlibrary.com under motors. It is listed as the "window motor" at the bottom. The hub for it is in the "Mechanical" section.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 25-01-2007, 10:35
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
That appears to be a different window motor from a past year. I emailed the address at FIRSTCADlibrary and asked if it was dimensionally the same and got no response yet.
Can you confirm that the model on FIRSTCADlibrary is the same as the one in the kit this year?
Thanks for the help,
RAZ
Unread 25-01-2007, 15:51
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
you could always pu thte motor in a mill to center find all the holes......if you have the resources that is...other that that, have you looked for a data sheet for the motor?
-John
2 motor adapter and keyang motor dimensions Bruno Estevão General Forum 1 16-02-2007 09:36
Keyang Window Motor Gear pitch AdamHeard Technical Discussion 3 19-01-2007 12:12
2 keyang motor to one spike? (was: need help..!!) itay_ms Technical Discussion 2 17-01-2007 13:07
2003 Drill Motor Drawing Joe P Inventor 4 14-05-2003 14:58
Keyang Motor Thermal breaker. archiver 2000 1 24-06-2002 00:24
