Go to Post SWARF is evil! - Al Skierkiewicz [more]
Unread 24-01-2007, 19:27
StashZabriski's Avatar
StashZabriski StashZabriski is offline
FRC #3320 (Miracles & Machines)
StashZabriski is on a distinguished road
Springs?!
Can we have springs on our robot?
Two ways:
1) Spring to keep a cable tensioned. (seems like this would be acceptable)
2) Piece that springs out after being deployed. (Does this violate the stored energy rule?)
I looked though the rules and couldn't find the answer for my team. Any help would be awesome!
Thanks,
~Stash~
No hunter of the sky should end his days as prey. Better to die on the wing than pinned to the ground. (Eragon by Christopher Paolini)
Unread 24-01-2007, 19:29
AdamHeard's Avatar
Lead Mentor
Re: Springs?!
I believe this falls under stored energy from deformed parts in rule <R02>. It should be legal unless it is deemed dangerous.
Unread 24-01-2007, 20:13
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: Springs?!
it is legal unless deemed a hazard. we checked it before
Unread 24-01-2007, 20:23
Re: Springs?!
Thanks! I skipped <R02> when I was going through the manual. Wasn't thinking of it as energy :-(
~Stash~
Unread 25-01-2007, 10:13
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Re: Springs?!
How do they determine if a spring is safe or not... Our team wants to deploy our ramp using spring loaded hinges and dampers to slow down the speed. I think as long as there was no way it could come undone during play outside the homezone this would be alright...Am i correct
Unread 25-01-2007, 10:46
Re: Springs?!
Stored energy devices will be checked when inspected. Things that inspectors will look for are items not designed as springs but used to store energy (i.e. deformed materials, surgical tubing, etc.) and those items designed for this purpose but implemented in a way that makes their use unsafe or beyond the design criteria of the part. There is nothing worse then to be standing on the sidelines and get hit by a spring that broke when it was tensioned beyond it's breaking point. (wow that hurts!)
Unread 25-01-2007, 13:59
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Springs?!
I'd be careful with using springs as a ramp deployment system. If it shoots out too fast then it could be deemed as a hazard to other robots.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Springs? tenfour Rules/Strategy 2 13-01-2004 11:58
Springs Mike Martus OCCRA 1 23-10-2003 02:28
Springs? Matthew Morris Technical Discussion 1 17-02-2003 09:48
springs hi_im_sean Technical Discussion 4 23-01-2003 19:05
springs CharlieWilken Technical Discussion 3 30-01-2002 19:39
