Go to Post I would like to know the team simply because it seems they could use a hug. - Taylor [more]
Unread 25-01-2007, 11:03
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
Running Banebots Transmission in Direct Drive
Does anyone think that running the Banesbot Transmission in direct drive is a bad idea?
Unread 25-01-2007, 11:36
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: Running Banebots Transmission in Direct Drive
Most likely, that means you are only putting a 12:1 reduction on the CIM motor... which depending on what size wheels you are using could be a bit fast. Do the the calculations with the motor specs from here and figure out how fast you will be running. Then we can give you a good idea if its too fast, usually a fast FIRST bot is 10 ft/, and a slow bot would be 3-4 ft/s. All depends on how you are playing the game.
edit: I would worry about putting that much load on the shafts of the gearbox's, i would highly recommend putting the bearing blocks on the other end of the shafts if you are direct driving it.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 25-01-2007, 11:55
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Running a CIM into the 12:1 banebots transmission with a 6" kitbot wheel gives you a 7.6 Feet/sec speed.
Going into an 8" wheel increases that speed to 11 feet/sec.
Unread 25-01-2007, 12:01
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
with the KOP 6" wheel it turns at 11 f/s and that sounds right if you've seen one run
Unread 25-01-2007, 12:15
jts jts is offline
FRC #0900
jts is on a distinguished road
Send a message via AIM to jts
It wouldn't necessarily be a bad idea if you used small enough wheels and supported the shaft. You can also purchase the gear change kit that would make it 16:1 instead of 12:1.
Unread 25-01-2007, 13:47
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
If you up the gear ratio, and used four gearboxes on four wheels, it would be possible. Make sure you connect the wheels together with a chain to transfer even torque to the front or back of the bot (in the event of a pushing match). You'd also need to make or order a hub for whatever wheel you are using, as well as a pillow block to support the shaft.
Now - would I recommend it? Not really. Gear it down with chains, and if those are too heavy use belts and pullys. If space is an issue then use some type of slim-2nd stage output gearbox with the outputting shaft running directly to the wheels.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 27-01-2007, 22:20
Jared Russell's Avatar
Taking a year (mostly) off
CIM free RPM = 5500-5750 (depending on which individual motor you test)
Reduction = 12:1
Output Shaft RPM = 5500-5750/12 = 458-479
Speed with a 6" wheel = 458-479 RPM / (60 sec/min) * (2*pi*3") / (12 in/ft) = 12-12.5fps
Speed with a 8" wheel = 458-479 RPM / (60 sec/min) * (2*pi*4") / (12 in/ft) = 16-17fps
Keep in mind that those are numbers assuming FREE SPINNING RPM. In reality, we find the loss to be about 25%, so with a 6" wheel you can expect a speed of about 9-10 fps and the speed with an 8" wheel to be about 12-13 fps.
Using two CIMs in the Banebots Transmission Justin M. Technical Discussion 15 09-01-2007 09:41
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Help! Direct Drive Issues roberthan Motors 16 21-09-2006 09:33
pic: 1097 Direct Drive 01 Anthony Kesich Robot Showcase 16 13-09-2005 22:33
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
