Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
Unread 24-01-2007, 10:24
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
How the GTS works?
I am trying to understand how the GTS/Accelometer works. If the GTS has counted one tick what distance came through, or who much degrees is one tick?
Thanks.
Unread 24-01-2007, 10:40
Electrical Engineer
Rookie Year: 1995
Re: How the GTS works?
Thanks.
The GTS is a Hall Effect gear tooth sensor. It senses "ticks" when a gear tooth passes near to the sensor. The size of the gear onto which the sensor is mounted, the gear ratio between that gear and the wheel and the diameter of the wheel are all specific to your design.
As to angle: If you have mounted the GTS next to a 60 tooth gear, the angular resolution is 6 degrees per tick.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 25-01-2007, 07:15
AKA: Nir Levanon
Ok, thank you very much.
Just another question, you mentioned that the gear tooth is to be moutned on the GTS. Were we supposed to recieve the gear tooth in the Kit of Parts? and if not, were can I get it?
Further more, how do I place the gear tooth on the GTS?
Unread 25-01-2007, 08:17
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
You should have gotten two sensors in your KoP. To mount the GTS, use nylon screws to mount it close (don't quote me on a distance) to the gear. We drilled holes in our AndyMark Transmissions to mount the GTS.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 25-01-2007, 10:08
SoD SoD is offline
FRC #2230
SoD is an unknown quantity at this point
Yes we got 2 sencors... why do we need both?
And where do we find the Gear Tooth and where should we place it? =/
Unread 25-01-2007, 11:27
You would use two gear tooth sensors if you wanted to sense and control the speed of two different gears. Think of the left and right side of the robot, for example.
You will find gear teeth at the periphery of any gear. You know the little pointy-shaped metal things that jut out from the gear and mesh with each other when two gears are placed together? Those are called teeth. That's what the gear tooth sensor senses.
Unread 25-01-2007, 21:46
KTorak's Avatar
Fire Rescue 47
AKA: Kyle Dersch
Team Role: Driver
Using two helps track your robot in a straight path because if one side spins faster than the other, the GTS will be off and you can make them correct the amount of gears to be equal by adjusting motor speed.
GTS Code Error (the red light of doom!) Denz Programming 9 07-04-2006 17:39
Where are the new sensors(2AA, YRG, GTS)?? Doug G Electrical 5 08-01-2006 21:50
We're on How Stuff Works?!? Redneck Chit-Chat 1 29-09-2005 18:32
How FIRST Works on howstuffworks.com Elgin Clock General Forum 2 15-05-2005 02:17
How Stuff Works: Segway Jnadke Dean Kamen's Inventions 3 17-07-2002 16:55
