Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 25-01-2007, 14:01
AKA: Brad
#0190 ( Gompei and the Herd)
Camera tracking demo in easyC or WPILib
Here is the shortest program that I could write that will track to a green light. It assumes 2 motors connected to PWM ports 1 and 2. Also the camera is fixed (no servoing). The robot will follow the light as long as it is seeing it.
Here is the easyC version (just the C code), but there is a link to an easyC Pro project and an MPLab project. There is also a link to a video showing it running on a FRC controller on a Vex robot chassis.
#include "Main.h"
void main ( void )
      unsigned char regionSize;
      unsigned char mx;
      int error;
      TwoWheelDrive(2,1); // The following 4 functions are built into WPILib, but have no blocks
      SetInvertedMotor(1); //    So they have to be user code blocks
      SetInvertedMotor(2);
      SetCameraDebugMode(1);
      InitCamera ( 1 ) ; // default FIRST green setup
      StartCamera ( ) ;
      while ( 1 )
            CaptureTrackingData ( &mx , 0 , 0 , 0 , 0 , 0 , &regionSize , 0 , 0 , 0 ) ;
            if ( regionSize > 10 )
                  error = ((int) mx) - 80 ;
                  Drive(50, error); // turn towards the light
            else
                  Drive(0, 0); // no light - stop driving
Brad Miller
Robotics Resource Center
Quetion about servo tracking function in easyC pro itsme Programming 5 31-01-2007 11:30
easyc demo code not working sniggel Programming 5 28-01-2007 16:40
Labview Demo File for 2006 Camera? JABianchi General Forum 2 15-09-2006 18:23
CMU Camera Tracking auditt241 Programming 0 03-02-2005 16:33
Camera Tracking Woes VideoMan053 Programming 4 29-01-2005 18:09
