Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 25-01-2007, 16:21
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
PHP Question
I want to print a number string but I'm having trouble.
$Value = '1234';
$Print_Value = $Current_Version[0] . $Current_Version[1] . $Current_Version[2] . $Current_Version[3] ;
echo ("$Print-Value");
I want it to print 1.2.3.4.
I know that $ST=$STR.$STR1 combines strings but I can't figure how to
get the desired output.
Unread 25-01-2007, 16:26
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: PHP Question
$a = 'bre';
$b = 'athe';
$out = $a.$b; // $out = breathe
$out = $a . '.' . $b; // $out = bre.athe
You need to also "dot" in the period. Even with that I still don't fully understand your question.. do you want to print the value in $Value, with periods between all the numbers, or are the digits in CurrentVersion?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 25-01-2007, 16:30
Kingofl337's Avatar
AKA: Adam
Re: PHP Question
rock on! Thanks!
Unread 25-01-2007, 16:36
felipe.tonello felipe.tonello is offline
Brazil rox!
AKA: Felipe Ferreri Tonello
FRC #1382 (Tribotec)
Team Role: Webmaster
felipe.tonello is on a distinguished road
Send a message via MSN to felipe.tonello
Re: PHP Question
PHP Code:
$Value
'1234';
$Print_Value '';
for (
$i 0$i strlen($Value); $i++){
  if (
$i != (strlen($Value) - 1))
$Print_Value .= $Value{$i} . '.';
  else
$Print_Value .= $Value{$i};
echo
$Print_Value;
I believe is something like that, you are waiting for..
just feedback if don't..
BRAZIL * #1382
Unread 25-01-2007, 16:40
Kingofl337's Avatar
AKA: Adam
Re: PHP Question
Ok one more
$Print_Version =  $Current_Version[0].'.'.$Current_Version[1].'.'.$Current_Version[2].'.'.$Current_Version[3];
$comment='<font color="red"><b>'.$Print_Version.'</b></font>';
I need the output to be in red 1.2.3.4
It's sending out 1234 in red
Unread 25-01-2007, 16:44
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: PHP Question
Originally Posted by Kingofl337 View Post
Ok one more
$comment='<font color="red"><b>'.$Current_Version.'</b></font>';
Change the $Current_Version in your second line to $Print_Version and you should be ok, if I'm understanding right.
Brandon Martus
e-mail
Unread 25-01-2007, 17:09
Kingofl337's Avatar
AKA: Adam
Re: PHP Question
Thanks for the idea, but, that didn't fix it. I Just copied it wrong. It's still printing 1234 instead of 1.2.3.4
Unread 25-01-2007, 19:45
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: PHP Question
wouldn't this work?
echo "$val[1].$val[2].$val[3].$val[4]";
KK4KQO
http://voltair.us
Unread 25-01-2007, 20:46
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Thumbs up Re: PHP Question
If you'd like to get fancy:
PHP Code:
// I like p instead of font :)
echo "<p style='color: red;'><b>";
foreach(
$Current_Version as $value) {
     echo
"$value.";
echo
"</b></p>"
There's probley other simple ways but meh its something to try if your stuck.
Amperage Robotics Team 1225
Site under-going revamp. :/
PHP question Billfred Website Design/Showcase 4 13-10-2004 09:48
PHP Question Joshua May Website Design/Showcase 9 11-06-2004 20:50
MySQL/PHP Query question Raven_Writer Website Design/Showcase 6 24-05-2004 18:09
PHP Question Raven_Writer Website Design/Showcase 2 22-05-2004 18:42
PHP bb... Stefan Website Design/Showcase 3 31-07-2003 13:48
