Re: Neon lights for Target Assembly
Ok
If the lights blow up.. it's not my fault!!!
Heh, the design schematics say to put all the lights (8) in a small box and cover it with that white plastic. Ours works great and the camera tracks pretty well with it.
Same here. We soldered a battery connector to our box wires and used an old one from last year. Works great, and the camera tracks it just fine.
We connected our light up to a computer electrical supply and are running two lights off of that. Hope that helps, just solder the cables to the connector and plug it in.
Thanks
#7
it might be a good idea to add a fuse in the circuit so if anything shorts out you wont run the risk of damaging a battery of possibly injuring someone.
some wall or bench top power supplies have built in fuses/ circuit breakers but if in doubt just add a fuse./forest |
| Lights (not the green target light) | FourPenguins | Electrical | 10 | 23-01-2007 13:23 |
| neon/strobes on bot | pyro20911d | General Forum | 22 | 06-03-2006 00:27 |
| Vision Target Assembly | platt | Kit & Additional Hardware | 4 | 26-01-2006 17:34 |
| pic: 234 Neon FIRST Logo | CD47-Bot | Extra Discussion | 24 | 01-03-2004 18:03 |
| English to metric for victor assembly? | Daniel Brim | Inventor | 3 | 07-02-2004 00:24 |
