Go to Post I love it when someone tells me I can't do something. - dlavery [more]
Unread 25-01-2007, 18:31
Reaper40's Avatar
Reaper40 Reaper40 is offline
FRC #2061
Team Role: Webmaster
Reaper40 is an unknown quantity at this point
what is the pressure switch?
how is wired
Unread 25-01-2007, 18:45
caraddicted101 caraddicted101 is offline
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
Re: what is the pressure switch?
You take a PWM cable and use two of the wires to wire to the switch. Everybody uses digital in/out 18.
Unread 25-01-2007, 18:52
Back after 4 years off
FRC #5279
The pressure switch (assuming it hasnt changed is a black cylender about an inch tall and an inch in diameter(give or take) on one side it has a brass threaded fitting (just like all the other pnuematic stuff), and on the other end it has 2 brass electrical leads.
caraddicted is right, If I recal it should be the white and black wires that you use. The only reason people use digital input 18 is because it is set up to turn off the last relay (I forget the number) in the default code. Basically, if you plug the switch into dig in 18 and the compressor spike into the last relay you dont need to change any code.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
