Go to Post However, I am a firm believer in the theory that if you are pushing with a mecanum wheeled robot you are doing it wrong. - Andrew Schreiber [more]
Unread 23-01-2007, 21:31
lndnny's Avatar
lndnny lndnny is offline
Does a bit of everything!
None #0808 (Mechanical Mayhem)
lndnny is an unknown quantity at this point
Question on Attaching Hubless Gears
Team 808 was unable to do FIRST this year so we decided to do a 150 lb sumo robot for http://www.nationalroboticschallenge.org/
We've decided to use hubless gears with keys and setscrews because we don't have the extra funds to aquire a hex broach in our current situation.
We were going to drill a hole into the face of the gear and into the bore. Then drill a clearance hole and thread the inch or so near the bore for a set screw.
Is this how teams have done it in the past? Is there a better way? We want to make sure the key stays in place and doesn't widen the keyway.
Our mentor wanted us to see if there was a better way of holding the key in place.
Thanks
Inventor Drawing coming once we build the sumobot
Fully autonomous 150 lb robots + IR Stealth = You can't see me!
Dan and Team 808
Unread 23-01-2007, 22:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Question on Attaching Hubless Gears
If you have a lathe and some decent lathing skills, you can use retaining rings. You can get heavy duty ones that will work plenty well, you just need to be able to lathe some reasonably good tolerance grooves on the shaft.
Unread 24-01-2007, 21:01
lndnny's Avatar
Thanks this was what we were going to do in addition to the key and setscrews. We wanted to know if the setscrew was possible. We figured that it was needed to prevent the key from smashing around in the keyway and widening it.
Team 808
Unread 24-01-2007, 21:27
Setscrews on keys are strictly to keep the key in place so it doesn't slide side to side axially. If it's "banging around" in the direction you're turning the gear, then the key is too small. Ideally, you get a slightly oversized key and file it down until it perfectly fits
Unread 25-01-2007, 18:44
lndnny's Avatar
thanks!
Team 808
Martin 20P hubless gears sanddrag Technical Discussion 3 24-06-2004 00:26
need help fast!!! Hubless 1/4 pitch sprockets Travis Covington General Forum 6 03-02-2003 18:44
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
spur gears & fishers ...newbie question... archiver 2001 3 23-06-2002 23:17
