Go to Post What is this "off season" of which you speak? - Alan Anderson [more]
Unread 25-01-2007, 18:09
haywirerobotics haywirerobotics is offline
FRC #1569 (Haywire)
haywirerobotics is on a distinguished road
Gameport to Usb cable vrs. Usb Chicklet
Ifi Has offered a "Usb Chicklet" for use with controllers, but this costs $130.
Teams can currently buy a Gameport to usb cable for around $20.
What are the performance and programming differences? In short, Why should we dish out the extra $110 for the chicklet? Thank you for your help in advance.
Haywire Robotics...
KISS
(Keep It Simple Stupid!)
Unread 25-01-2007, 18:15
Darkforces's Avatar
Darkforces Darkforces is offline
Froforces
AKA: Taylor Burch
FRC #1875 (Autonomato Atonamatons)
Darkforces will become famous soon enoughDarkforces will become famous soon enough
Send a message via AIM to Darkforces
Re: Serial to Usb cable vrs. Usb Chicklet
the operator interface isn't serial its a game port like on the back of sound cards. It has a row of 8 and 7 instead of serial which a row of 4 and 5. Good idea but unfortunately it wont work.
Unread 25-01-2007, 18:19
FRC #1569 (Haywire)
Ok well a game to usb port then Same thing... What I want to know is what does The chicklet offer special?
Haywire Robotics...
KISS
Unread 25-01-2007, 18:54
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Gameport to Usb cable vrs. Usb Chicklet
You are right on one fact- GamePort to USB converters are cheap and available. These however run only in one direction. USB to Gameport converters are a little different, and a lot harder to create.
First of all, the USB allows for a relatively large amount of power to be passed through the port to power lots of stuff. Like Gameport pots and switches, and the hardware needed to convert the Gameport's analog signals to the USB digital protocol. IFI's OI does not provide for the amount of current needed to run a USB device, and the hardware needed to change USB to analog voltages on individual pins. You cannot reasonably create a USB to Gameport converter without adding another power source- which is what the chicklet does. This is part of the explanation of why the converters only work in one direction.
Apart from power, there are two separate entities in any USB system- slave devices (any USB device you buy pretty much), and a central USB host controller, which is what your computer does. The gameport to USB converter acts as a slave to a computer, and therefore does not need complex hardware to operate. It looks at it's own hardware, and relays that to the host when instructed. It talks when the host tells it to.
However, the host controller must be must more complex, because it has to give the orders to the slave devices. It's responsible for polling and servicing the slaves, not just feeding information. It then has to take the information that the slave provides and convert that to voltages on the individual Gameport pins. As you can see, it takes alot more work to create a USB host than a USB slave, and that's why the Chicklet has been so long in coming.
Why it's $130, I don't know. Startup costs I suppose. Regardless, its a wonderful option to free teams from the terrible white joysticks we have been getting the past few years. But you really have no other options.
-Sir Francis Bacon
-Albert Einstein
Unread 25-01-2007, 19:03
Darkforces's Avatar
Froforces
AKA: Taylor Burch
Our team has looked for an adapter but we only found male usb to female gameport and you need a female usb plug to connect your controller to. Check out these 15 pin logitech joysticks: Wingman Extreme 3D, and the logitech attack series of joysticks. just make sure that you get the 15 pin version not the usb version.
USB Chicklet SleeveofWizard Control System 11 28-01-2007 22:45
Subforum suggestion: USB Chicklet discussion Billfred CD Forum Support 3 17-01-2007 22:56
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
usb to serial cable karinka13 Technical Discussion 4 10-02-2006 17:30
USB-Serial Cable + Terminal Spencer E. Programming 3 22-01-2006 12:16
