Go to Post How many FIRSTers would quit if they found it was bad for them? I think most FIRSTaholics are thirteen steppers ;) - phrontist [more]
Unread 25-01-2007, 19:17
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Exclamation KOP Joystick thumb pad
Hi,
we are trying to use the little 8 position thumbstick on the KOP joystick and are having some problems, in easy c, when you try to get the Digital OI Input in the RC Control section, it asks for a button, what button is the forward and reverse on the thumbstick, or how do i find out what it is?
thanks
malhon
Unread 25-01-2007, 19:33
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: KOP Joystick thumb pad
to my knowledge(and I have taken these things apart) the thumb pad is not wired in to the DB15 port.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 25-01-2007, 19:35
AKA: Malhon Godwin
What buttons are wired into the db15 port
thanks
malhon
Unread 25-01-2007, 19:38
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
thanks
malhon
Here is a good diagram. I forgot who made it though, but thank him.
http://www.chiefdelphi.com/media/img...5ff3a611_l.jpg
I beilive everything but that thumb pad is used. But look at that diagram and just try it out. If its not listed in EasyC its probably not wired.
Unread 25-01-2007, 19:42
AKA: Malhon Godwin
thanks! this helps a lot, glad we didn't waste anymore time trying to figure it out!
thanks
malhon
Unread 25-01-2007, 19:43
Stuart's Avatar
#include coffee.h
the trigger, the 2 buttons to the either side of the thumb pad, and the button to on the side(where your thumb goes)
Unread 25-01-2007, 21:13
The multidirectional "hat" switch is connected to the analog "wheel" pin on the joystick port. Use the Dashboard Viewer program to see what values correspond to each direction.
(By the way, it only has four real directions, but some of the diagonal combinations do give unique values.)
Free DDR pad (well sorta) Andrew Rudolph Chit-Chat 8 06-09-2006 18:04
Worn brake pad... mechanicalbrain Chit-Chat 12 16-01-2006 17:25
pic: Our DDR Pad! Sachiel7 Robot Showcase 2 17-02-2005 12:01
Rule - Human Players On Either Pad? Ralph Lambert Rules/Strategy 1 08-01-2003 09:03
2002 Referee Scoring Pad Digo General Forum 11 18-05-2002 12:42
