Go to Post Uncle Sam wants you to watch NERD Vision. - artdutra04 [more]
Unread 25-01-2007, 20:23
teh_r4v3 teh_r4v3 is offline
AKA: Rajeev Sharma
FRC #1511 (Rolling Thunder)
Team Role: Student
teh_r4v3 is on a distinguished road
Send a message via AIM to teh_r4v3
Robot controller will not program
Hey everybody, we're having some serious problems with our RC. Here are the symptoms:
When the OI is connected in any way (tether or radio), the program mode light is stuck at solid yellow. Nothing will stop it. When the OI is disconnected, the lights go green and we can start up the programming mode, but it doesn't work when we try to transfer. When we try to program, it starts going for a bit, starts to clear the memory, then gives a nice "Not connected..." error.
We've checked every electrical connection, disconnected everything from the electrical board except for the controller, battery, and associated breaker, and used the special reset button combo on the RC (hold down PROG + RESET, then PROG, etc...). We're kind of stuck here. We plan on calling IFI tomorrow, but do any of you have any ideas in the meantime?
Rajeev Sharma
Team 1511 Rolling Thunder
hoojamomma?
Unread 25-01-2007, 20:29
Electrical Engineer
Rookie Year: 1995
Re: Robot controller will not program
This may be obvious but have you checked your battery voltage?
Mike Betts
As easy as 355/113...
Unread 25-01-2007, 22:38
AKA: Rajeev Sharma
Team Role: Student
We finally figured out what it was. Turns out something wacky was going on with our laptop's serial port! Effectively, it was corrupting the code on the RC. (We realized this when we plugged in last year's board, and upon programming it suddenly displayed the same symptoms, much to our dismay!) It seems to be cured now; the RC took the hex from another laptop easily. We reworked some BIOS settings on the laptop for the COM port and now even that laptop is working fine. Altogether, it's been a pretty bizarre night. Anyways, so if anyone is having a similar problem, try using another laptop!
Rajeev Sharma
hoojamomma?
How Can I Program The FRC Robot Controller To Display My Team Number jesusescobar Programming 5 22-01-2007 10:29
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
HELP! Can't Program Robot Controller - LED stays on. sheyna Programming 3 21-01-2006 18:50
Can we not ship Robot Controller? Doug G General Forum 8 22-02-2005 17:33
Robot Controller Not Working !?!?! Team1425 Electrical 3 24-01-2004 20:52
