Go to Post Parallax is evil. - RoboChair [more]
Unread 25-01-2007, 20:41
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Post Camera for turning
I am using a combination of the camera and a gyro to turn until the camera is lined up with the green light. With the code I'm using the robot just rotates back and forth and will never stop. Is there a better way to accomplish this. Here is the code:
Camera_Handler();
Servo_Track();
temp_gyro = Get_Gyro_Angle();
tracking_state = Get_Tracking_State();
printf("gyro_angle = %d\r\n", (int)temp_gyro);
if(capture == 0 && tracking_state == CAMERA_ON_TARGET )
goal_angle = ((((int)PAN_SERVO - 124) * 65)/124);
capture = 1;
milliradian_goal = ((goal_angle * 3.1415 * 1000)/180);
if(capture == 1)
if((milliradian_goal - 60) < temp_gyro)
pwm03 = pwm06 = 150; //Turns robot left
pwm04 = pwm05 = 150;
if(temp_gyro < milliradian_goal + 60)
pwm03 = pwm06 = 104; //Turns robot right
pwm04 = pwm05 = 104;
if(((milliradian_goal + 60) >= temp_gyro) && (temp_gyro >= (milliradian_goal - 60)))
pwm03 = pwm06 = 127;
pwm04 = pwm05 = 127;
capture = 2;
Unread 25-01-2007, 20:46
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Camera for turning
Camera_Handler();
Servo_Track();
printf(&quot;gyro_angle = %d\r\n&quot;, (int)temp_gyro);
capture = 1;
if(capture == 1)
capture = 2;
Why are you setting all four PWM outs to the same value? If you want to turn left, set your right motors forward and your left motors either stopped or reversed and opposite for turning right.
Unread 25-01-2007, 20:53
The motors on the left side have to go in reverse in order to move the robot forward. So by using the same number the left side wheels and the right side wheels go opposite directions.
Unread 25-01-2007, 20:57
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
OK, we usually wire the motors up with the left motor polarities being opposite the right motor polarites so that 254==full forawrd on both the left and the right sides. Sorry bout that. In this case I would suggest using a proportional control loop where the output applied to the motors scales itself to the amount of error, lestening the oscillations.
Unread 25-01-2007, 21:33
I have messed around with control loops before build season but never could get one to work correctly. Could you post example?
Unread 25-01-2007, 21:52
Making the motor speed proportional to the error will stop the oscillations if the proportional constant is low enough. But then you'll probably find the robot won't quite get to the desired angle, and you'll want to add some error integration to force it to move after it's been off-angle long enough. At that point, you might have some overshoot, and to fix that requires some negative feedback based on the rate of change of the error.
In short, it's time to implement a PID control system for your robot direction. Search the forums to find plenty of information, and even some code, that will do what you need.
Unread 25-01-2007, 22:18
I have actually searched all over chiefdelphi for information. I found a lot except that I couldn't find anything about an output to control more than one pwm.
Unread 25-01-2007, 22:24
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
i actually have a bit of code that may help you.
PHP Code:
unsigned char PIkDControl(char Kpchar Kichar Kdint error) {
    static
int errorTotal 0;  //there is a better way to do this... meh
static int prevError 0;
int P 0;
int I 0;
int D 0;
= (error*Kp)/100;
= (errorTotal*Ki)/100;
= ((error prevError)*Kd)/100;
errorTotal += error;
prevError error;
    return  (
Limit_Mix(2000+127+P+I-D));
There are a couple of other tweaks, but i edited them out. you should come across them whilst testing (=
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 25-01-2007, 22:26
Thanks, I'll try that. One question: What's the limit mix for. I have never seen it on a control loop.
Unread 25-01-2007, 22:47
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
limiting output, of course. you don't want your unsigned char to overflow, that would be bad
RPI 2012
BREAKAWAY
...I couldn't find anything about an output to control more than one pwm.
A brief look at your existing code reveals that to be a non-issue. If you supply the same PID-computed value to all your motor pwms, your robot will turn in place. That's exactly what you want it to do, isn't it?
Unread 25-01-2007, 22:48
While using your code how do i implement a target value and how do I out put it to four motors. Sorry for all the questions but PID loops are still very new to me.
Unread 25-01-2007, 23:46
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
the function is returning a motor value from 0-255. it is up to you to map it to your motors, like you would a joystick.
as for inputting the error... you need to figure out your error much like you did in your original loop. with the dual targets this year, though, you will have to do a little (lot) of extra math and AI to get your desired target.
RPI 2012
BREAKAWAY
Unread 26-01-2007, 00:18
PID Without a Ph.D
All you had to do was ask...
Unread 26-01-2007, 20:44
Thanks a lot for all of your help. I finally got a PID loop running and it works great.
Turning 18... Astronouth7303 Chit-Chat 16 22-05-2006 09:29
Turning Trouble! Cadetdan General Forum 18 05-03-2005 08:55
Slowing down Camera drive turning Zalumaskov Programming 1 27-02-2005 10:11
Connections For Camera Eupher Programming 3 02-02-2005 14:35
Canadian fined for turning left while on his Segway MrToast Dean Kamen's Inventions 2 21-10-2004 17:34
