Go to Post Do one thing, and do that one thing very well. - Arille [more]
Unread 25-01-2007, 18:50
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Talking buying 40 amp maxi fuse blocks
Where can one purchase the 40 amp maxi fuse blocks, 2007 model?
thank you!!!
Unread 25-01-2007, 21:55
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: buying 40 amp maxi fuse blocks
http://www.walmart.com/catalog/produ...uct_id=2606832
Something like that? If not try googling some more.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 25-01-2007, 22:00
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
The 2007 model is the same as the 2006 and 2004 model. Try Terminal Supply.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 26-01-2007, 01:46
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Well, you could always search the forums here, as I'm SURE someone else has tried to purchase these before.
Oh, look what I found.
BEN
Modifying 40 Amp maxi fuse block kborer22 Electrical 18 23-01-2007 10:12
Maxi style fuse box Ken Loyd Technical Discussion 4 31-01-2006 13:55
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Maxi 40 Amp Fuse Panel mtrawls Electrical 25 13-02-2004 15:19
Reliable Connections to the fuse blocks. Al Skierkiewicz Electrical 0 09-02-2004 12:01
