Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 24-01-2007, 17:11
chapmatr's Avatar
chapmatr chapmatr is offline
Zippidy bling-zap whippy-wog snizin
AKA: Travis (Lead Programmer)
FRC #1676 (Pascack Pioneers)
Team Role: Driver
chapmatr is an unknown quantity at this point
Send a message via AIM to chapmatr
EasyC deadzones?
We've been doing a lot today, sorry with all the questions. What we need is access to the deadzones for easyC- it's too large for us. Where can we change this? I found the drive functions library, but I can't make much sense of it. Please help.
Did you know that 87% of all online statiscs are made up?
Unread 24-01-2007, 23:02
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: EasyC deadzones?
I really think you would benefit from taking a little time to run through some of the tutorials available in the Help menu. Try it! Really!
Deadzones are something you program. In general, your joystick position arrives at your program as a raw number. Your program performs certain actions based on that number, as in drive in a certain direction at a certain speed. Some of the EasyC drive libraries are there to make that task simpler. To establish dead zones, you simply make sure that if the raw number from your joy stick is between a certain range (say 107 to 137) then your program treats it as 127 (neutral). Here is psuedo code:
if (joyX >= 107 || joyX <= 137)
xValue = 127;
Unread 24-01-2007, 23:08
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
xValue = 127;
Actually, you would want to use an && there instead of an ||.
if (joyX >= 107 && joyX <= 137)
xValue = 127;
Art Dutra IV
世上无难事,只怕有心人.
Unread 25-01-2007, 09:33
AKA: Dan
Yes you are correct!
Unread 25-01-2007, 10:08
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
The default drive functions shouldn't have any deadband. If you using the code I made and posted in the FRC forum the deadband is in the globals.
Unread 25-01-2007, 14:23
chapmatr's Avatar
Team Role: Driver
hm...well, our joysticks don't even respond until you push halfway there...one of our teachers mentioned linear regression? How can I fix that, without a smoothing algorithim. If I have to, I'll make one.
Unread 25-01-2007, 22:47
Kingofl337's Avatar
AKA: Adam
You should make a quick program to look at the values being returned in the graphics display. Maybe something is wrong with the joysticks or OI? If you look at my code in FRC "Default Drive Code" I have a scaling in that file you can use for an example.
installing easyC MarkH Programming 2 26-03-2006 07:33
easyC upgrade! Brandon Martus Announcements 0 07-03-2006 14:44
easyC trouble Erics626 Programming 10 02-02-2006 08:10
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
