Go to Post Michigan is all about tough love. If you can make it there you can make it anywhere. - Koko Ed [more]
Unread 25-01-2007, 22:58
bigboi146's Avatar
bigboi146 bigboi146 is offline
AKA: Marcus
FRC #1660 (Harlem Knights)
Team Role: Driver
bigboi146 is an unknown quantity at this point
Send a message via AIM to bigboi146 Send a message via Yahoo to bigboi146
Andymark single speed and KOP chassis
Greetings from team 1660(Harlem Knights).
We are looking for ways to mount the single speed gearbox from andymark on our KOP chassis. If anyone has any suggestions and or pictures it would be greatly appreciated.
-1660!!!
TEAM 713
2001 Feather Weight Award
2001 New York regional winners
2001 First seed.
TEAM 1660
2005 Judges award
2005 New York Regional Finalist
2006 Safety Award
2006 General motors Industrial Design
Unread 25-01-2007, 23:20
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Andymark single speed and KOP chassis
Your best bet would be to drill holes into the gear box to use to bolt to the chasis. Unless you can use longer bolts than the ones supplied, and bolt the gear box directly to a support bar.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 25-01-2007, 23:43
Billfred's Avatar
Billfred Billfred is online now
Alternatively, you may do well to get a sturdy piece of aluminum angle, bolt the gearbox on its face to that, then bolt the angle to your frame. Sort of like the 2005-2006 setup, but different.
Unread 26-01-2007, 00:52
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
what 996 is planning to do is machine our own metal plates, bolt the gearboxes onto those, and then bolt the plate/gearbox combination to the kop frame with a possibility of using an angled piece of aluminum to secure two gearboxes across the frame. probably doesn't make much sense... but maybe it helped
Team #996 Programmer/President/Comedy Relief
"Why not stop by the robotics meeting after school today?" -Mr. Murray (enlisting me)
Unread 26-01-2007, 01:23
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
I suggest that you look at what Team 121 is doing with their kit frame and AM single speed transmissions. In fact, they can probably answer any questions you have about mounting, lubrication, and break-in of these transmissions. You can find many of their pictures here.
Good Luck,
BEN
Unread 26-01-2007, 08:31
TD78 TD78 is online now
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
We used a piece of aluminum flat stock with two hole patterns drilled out: one for the kit chassis on the bottom and one for the AM transmissions on top. You should be able to see an example here (it's the third image on the page if it doesn't link you directly). We are actually in the process of making some new plates that have slots where we mount to the chassis so we slide the transmissions back and forth for chain tensioning. You will probably also want to design a stiffener plate that spans the width of the chassis and bolts in some fashion to the holes at the tops of the AM transmissions. We made ours out of sheetmetal with the edges turned up for extra strength. In addition, it helps stiffen the chassis and prevents twisting and racking (much like the kitbot stiffener plate that came with the kit the last two years). This plate was installed at last night's meeting (which I didn't attend), but there should be pictures up on Joe Menassa's website soon. Good luck.
-Tom
FRC78: 2010-Present
FRC121: 2002-2009
Unread 26-01-2007, 21:26
bigboi146's Avatar
AKA: Marcus
Team Role: Driver
Thanks for all the input guys. We have founda way to mount it. Its going on as I am typing this. Ill get pictures up soon.
TEAM 713
2001 First seed.
TEAM 1660
2005 Judges award
2006 Safety Award
AndyMark 2-speed transmissions gabrielse Kit & Additional Hardware 3 08-01-2007 11:32
KOP Chassis & Transmission Inventor 8 Files JVN Inventor 0 12-01-2005 15:00
KOP Chassis & Transmission Support/Documentation JVN Technical Discussion 0 10-01-2005 00:28
White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox CD47-Bot Extra Discussion 9 30-08-2004 21:57
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
