Re: Important Q/A forum responses
Joey, et al,
You can use almost anything that is COTS or manufactured by the team for the OI. But because the CH Flightsticks are no longer manufactered, they are not COTS and not allowed. JMHO Mike Last edited by Mike Betts : 26-01-2007 at 00:52. |
I posted a Q&A question about old CH joysticks and other analog joysticks from eBay and the like, just for clarifications.
I'll tell ya though, FIRST has really done a number on poor teams this time around. What I don't like about this is some guy called "GDC" has just with one line of text, potentially cost the FIRST program over $100,000 EDIT: Please read the posts below. It appears CH Flightsticks may not be outlawed afterall. Last edited by sanddrag : 26-01-2007 at 03:16. |
It would appear that COTS items that are no longer commercially available can be used, as long they are in vendor delivered condition. Eugene |
#7
Hooray Eugene Brooks and Karthik! Team Update 2 to the rescue? Seems like it eh?
#9
I wonder if FIRST is going to emphasize inspection of the operator controls this year? I think last year we just looked at the size, OI vintage and whether the right team number and firmware came up.
#10
All,
I missed that one... As amended, <G28> does allow for the CH Flightsticks. Regards, Mike |
#11
I missed it, too. Thanks to Eugene and Karthik... it sounds like the OI will be okay after all.
#12
Here's one that's going to get a lot of people, if it's not publicized...
Even though the rule makes a lot of sense in the theory of "all power from the robot," logistically, it's a disaster. Hypothetically this means that you cannot use an offboard battery to power the compressor, even if you're using it at the competition. Why? Because the battery to power the compressor would count as a SECOND battery, and you're only allowed one battery to power your robot per match. Teams will HAVE to find a way to "port in" to their robot to power the compressor (like an electrical outlet). This is easily accomplished by having a couple of unused Anderson Connectors attached to the outside frame of your robot, connected to the rest of your wiring harness. Just plug, pressurize, and go! |
#14
Please remember that at the base of this issue with off board compressors is the need to demonstrate that the compressor will shut down under RC control which precludes the need for the compressor to be powered through a spike from the same battery used to power the RC.
#15
I'm much more concerned about the fact that ALL robot prep must happen with the competition battery. I understand the logic there, but keeping track of whether you're testing and debugging or actually resetting devices on your robot for a match will be a real nightmare. What if you've been debugging over lunch with a non-comp battery and parts of your robot end up in reset position and then you forget that you did so over lunch and don't re-reset them with a comp battery? I'm thinking that they'll almost have to be a bit lenient with this one and only come down on blatant repeat offenders. It's not as if you can scan the robot with a tricorder and find out if the quantum wave stat of the last electrons to course through it match a competition battery... |
| [Forum Help]: Forum tags | Ken Leung | CD Forum Support | 8 | 17-01-2005 12:28 |
| TechnoKats' designs - responses needed | Andy Baker | Chairman's Award | 0 | 29-01-2003 09:52 |
| Official Rule responses | EStokely | General Forum | 4 | 11-01-2003 01:29 |
| Strategic Responses | Hubicki | Rules/Strategy | 16 | 22-01-2002 17:11 |
| How important is it to register in this forum? | Ken Leung | General Forum | 6 | 12-06-2001 21:14 |
