#16
Re: pic: Servo Controlled Valve
Maybe I'm oversimplifying this but. Why not just run an additional variable regulator downstream between the solenoid valve and the vacuum generator?
This way you can operate the kit valves at an increased pressure (ie: 60psi) and then regulate the pressure down to your desired psi for the vacuum generator. |
| PC Controlled Robot | EHaskins | Programming | 6 | 05-11-2006 06:45 |
| pic: pneumatic actuation of ball valve | Andrew Schuetze | Extra Discussion | 2 | 30-10-2006 08:40 |
| Camera Controlled Robot | douglass1371 | Programming | 1 | 19-02-2006 19:22 |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| Servos controlled by RC? | Obi | Programming | 5 | 01-02-2005 14:43 |
