Go to Post If anybody ever uses a terabyte in the next few years the world would probably come to an end - spadercool [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 25-01-2007, 01:28
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
How fast does the Solenoids turn on and off?
I would like to use the solenoids in a switching purpose, does anyone know how fast they can switch on and off? and the delay times on these things?
Unread 25-01-2007, 08:59
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: How fast does the Solenoids turn on and off?
By solonoids, I'm assuming you are meaning the solonoid valves in the kit.
The answer, in short, is it depends on the pressure on the valve. However, that said, most solonoid valves will react in under 20ms. The first pull in is usually the worst case for pull in time, and the length of time energized effects drop out time (seat compression and heating).
Unread 26-01-2007, 01:09
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Nope, I was refering to the Solenoid Out on the MINI RC.
Anyone know how fast the Solenoids on the MINI RC can turn on and off? Generalx5 Control System 1 06-01-2007 07:39
does the turn on/off swicht have to be assessable FlyingDutchman Electrical 10 05-02-2006 16:45
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
Can I turn off the touchpad on my laptop? (Dell Inspiron 8100) Elgin Clock Technical Discussion 8 03-07-2004 13:59
How fast is fast to get on the hill? ianbbat General Forum 76 09-03-2003 21:05
