Go to Post Progress should never made at the expense of the past. - Koko Ed [more]
  #46   Spotlight this post!
Unread 18-01-2007, 21:51
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: Risk of the Lift?
Why can't pneumatics lift? We used a 2-inch cylinder in 2004 to lift our robot and that was pulling. If you look at the math that 2-inch cylinder (the actual piston was probably smaller, lets say 1.5 inches) has 7 square inches of pushing power. At 60 psi that means that cylinder has 424 pounds of force. Now lets lower that estimate some for efficiency and put it at a mere 300 pounds just for fun. That means that with the number that our team currently owns (two) we could lift 5 robots off the floor to a height of about 3 ft. If we didn't lift us then with two we could lift every other robot on the field. They have more than enough power to lift your entire team.
However, I don't think that would be the way to do it cause that takes a long time to charge up for (and more than all of the storage that we got). I think a motor winch would be better suited. Also why is a lift more dangerous than a ramp? When rolling up a ramp the robot is moving on a very narrow surface and might drift without the driver being able to tell. When a lift is working then all of the force is vertical, that robot only moves up and not laterally (hopefully). No lateral force result in no lateral motion and so how does the robot topple? If the lift is done well I bet that it’s safer than a ramp cause it can be better automated.
Just a couple of thoughts
  #47   Spotlight this post!
Unread 18-01-2007, 22:35
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
While yes there is a danger in the lift, dont forget we were jumping off a foot tall ramp last year.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
  #48   Spotlight this post!
Unread 19-01-2007, 00:20
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
While both the ramp and the lift have their dangers I think the ramp is a little more dangerous to the robot being climbed specifically if there is a arm or tube manipulator it. This can be prevented a little easier with something to keep the lifted robot from swinging into you.
Also, as far as pnuematics being too weak to lift a robot, (which, as its been said they are not) there is nothing ruling against aiding the piston(s) to lift a robot, such as gas springs or a pulley reduction.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
  #49   Spotlight this post!
Unread 19-01-2007, 21:44
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
The problem I forsee with pnuematics is volume of air, and weight of the system. There is the Bane Bots Transmission that is a 128:1 ratio. That my friends is serious torque. Also in regards to lifting, It would almost have to be done with a non cantilievered lift because you just won't have the counter balancing ability when you (a 135 lb robot) are lifting another 135 lb robot. Do what you will we are in the process of building our lift system this weekend I'll let you know if it works or not.
  #50   Spotlight this post!
Unread 20-01-2007, 16:59
cam1031's Avatar
cam1031 cam1031 is offline
FRC #1835
cam1031 is an unknown quantity at this point
why lift from above when you could just use something as easy as a ramp where there is no chance of tipping
  #51   Spotlight this post!
Unread 24-01-2007, 13:33
rockit science rockit science is offline
rockit science is an unknown quantity at this point
You may want to look at the math AGAIN. The cylinders are rated on the actual piston diameter, so a 2" cylinder has a 2" diameter piston. When you do the math, a 2" piston has a surface area of 3.14 square inches. At 60 psig, this equals 188 lbs. of lifting force. In addition, I believe the longest stroke you can get is 24". You are correct that these things require a LOT of air volume. We used a 2" x 24" to lift ourselves in "Raising the Bar" and it took a good 30 seconds to get us all the way up.
  #52   Spotlight this post!
Unread 24-01-2007, 14:05
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by firstbots195 View Post
It is almost going to be impossible to use a lift to elevate your alliance's robots. It is going to be impossible because pneumanic cylinders are not going to give enough force to exert a lifting device.
The 2" Bimba cylindar has a push factor of just over 3. So 60PSI in the cylindar will provide just over 180 pounds of pushing force . In other words, a single 2" cylindar has the pushing force to lift a robot.
Believe me, there will be a LOT of successful lifts.
As far as which is safer ... both are just as safe. The same amount of energy will be in either design because you are raising the robot the same height. Damage occurs only when that energy is expended (IE a robot hits the floor). The difference is who's in control of the robot at the time of an accident .
  #53   Spotlight this post!
Unread 24-01-2007, 14:25
pyrome's Avatar
pyrome pyrome is offline
Driver, Programmer, Engineer
FRC #0852 (Athenian Robotics Collective (ARC))
Team Role: Operator
pyrome is on a distinguished road
Originally Posted by DeepWater View Post
Hmm, You must have been watching a different competition than I was last year. The number of teams that couldn't climb the ramp surprised me. The number of teams that tried to climb the ramp and fell over astounded me.
The ramp was angled more off the ground last year. This year we have the option of making the ramp relatively flat.
Mark Ellis
A.K.A.
Markapopalis
Markola
Markali
Markalis
Markolas
Polo
Marco
  #54   Spotlight this post!
Unread 25-01-2007, 07:33
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Last year the ramp angle was known and robots were designed to climb them (and still many failed). This year, if an alliance robot has a ramp, the angle will not be known, the width may, or may not be sufficient, and some robots will not be designed to climb a ramp. Last years ramp was a solid unmoving structure, this year (if a robot has a ramp) it will be mobile, and probably flex under load. Remember, the longer you make it, the more structure it needs to support the weigh. Lets hope people dont weight reduce structural members.
So even a 'relatively flat' ramp may prove to be a difficult (if not impossible) obsticle.
  #55   Spotlight this post!
Unread 25-01-2007, 10:27
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
All I know is that at the competition I know there has to be an alliance where one robot will go onto another robot and then that robot will try to lift the other and then all three will flip over and the whole regional will go quiet while this happens. Oh and the pit area is going to freak out with the silence too probably.
  #56   Spotlight this post!
Unread 26-01-2007, 08:50
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
My nightmare begins with a rookie team driving up our ramp full speed and crashing into our ringer arm. Ramps give me grey hair....oops, all my hair is grey as I type.
Ken
Ken Loyd
Teacher/Advisor
Team #39
Highland High School
  #57   Spotlight this post!
Unread 26-01-2007, 13:50
AKA: Charlie Baxter
Ken
I had an interesting thought. Lets say that my team has two independently lifting platforms set up so that the other two alliance members can drive on and be lifted when they are safely on and stop. Would it be worthwhile to have the other two alliance members hit the disbale button when they are on so they don't accidentally drive off and give us a reputation as a robot dropper.
  #58   Spotlight this post!
Unread 28-01-2007, 12:15
RaMoore's Avatar
RaMoore RaMoore is offline
AKA: Rachel Moore
FRC #3005 (RoboChargers)
RaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud of
The strategy when you go with a lifter(or ramp, just call it a +12" bot) is that you want to get picked is my take. So you need to prove in someway that you're an awesome +12" bot. Ideally with a good design, despite alliance drivers errors you should still get a chance to be picked... but lots of teams have (poor) picking processes based entirely on reputation/record so I think you're right that track record is going to be really important.
1817 is going with a +12" bot this year and we have been wondering the same thing about the disable idea. Ramp or lift either way, I expect to see alot of robots try to descore themselves by operator error. I've been wondering how well other teams will take to the idea that we are asking them to disable themselves.
Rachel Moore
REV Robotics | www.revrobotics.com
  #59   Spotlight this post!
Unread 28-01-2007, 12:33
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Its even worse than that. That 2" cylinder can hold 188 lbs - it cannot lift 188 lbs. We have done experiments on "Pneumatic Power" and I presented this at the National conference last year.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
  #60   Spotlight this post!
Unread 28-01-2007, 12:39
RaMoore's Avatar
AKA: Rachel Moore
Could you be more specific with what teams can expect then for lifting? 1/2 of 188lbs? 1/4 of 188 lbs?
Just some ball park estimate because I think alot of teams did the math and came up with 188lbs and rejoiced (we did). If this isn't what they should expect then I think i'ts important you get information out there.
Rachel Moore
Risk tournament [527]phil Games/Trivia 1 29-09-2005 17:22
Interface of the window lift motors Marjory Frosty Motors 3 14-01-2005 22:57
PHP as a security risk purplehaze357 Website Design/Showcase 9 02-07-2003 21:50
A little lift for the final week George1902 General Forum 1 11-02-2003 22:48
Amount of Force to lift the bridge? archiver 2001 2 23-06-2002 23:21
