Go to Post If you have to build the best robot to be inspired then we end up with one winning inspired team, and 999 losers. That is not the spirit of FIRST. - KenWittlief [more]
  #46   Spotlight this post!
Unread 24-01-2007, 15:42
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Problem with program uploading
"there is suddenly no controller to download code to."
Out of curiousity, how did this manifest itself? Was there an error or did the download just hang or was there some other symptom?
thanks.
  #47   Spotlight this post!
Unread 25-01-2007, 07:20
1573's Avatar
1573 1573 is offline
FRC #1573 (KGSTARS)
1573 is an unknown quantity at this point
Send a message via ICQ to 1573
when im trying to upload the program to the controller the computer isent recognizing the controllers version (2006/2007 controller).
but it does recognizes the 2005 controller
  #48   Spotlight this post!
Unread 25-01-2007, 14:15
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Sounds like it may be the same problem I had with the actual controller. I tried our 06 RC and worked fine then tried the 07 and wouldnt work. I called IFI and he went through all the steps everyone on here did and told me to send it in and they'll check it out. I am wondering if part of the processors are goofed up or the actual program input interface.
Oh well now I just wait a few more days to get it back.
-Mike
  #49   Spotlight this post!
Unread 26-01-2007, 08:56
1573's Avatar
FRC #1573 (KGSTARS)
YAI, ok i found the problem.... i tried 3 computers then i tried at home and its works correctly there so the wole problem was the 3 computers. thank you guys for the help
  #50   Spotlight this post!
Unread 28-01-2007, 13:51
Mib Mib is offline
AKA: Aaron Clay
FRC #1741 (Red Alert Robotics)
Mib is on a distinguished road
Send a message via AIM to Mib Send a message via MSN to Mib Send a message via Yahoo to Mib
Originally Posted by jesusfreakmths View Post
Do you guys know were I can find the code for the camra. Or any info on how to use it, and see code that can give us an idea on how to include it in the code/recive info from it?
www.kevin.org
click on FRC stuff ("here")
scroll down, and it should be called something like frc_first_camera2
get the bells and whistles if you're doing a lot of stuff with autonomous mode, the streamlined version is ok though
you'll have to upload it to the camera/robot, but after that, the camera should be able to track targets and display feedback
Aaron M. Clay
Programming Consultent
www.GameCopyWorld.com
amclay (@) purdue.edu
Program Build Problem douglass1371 Programming 3 18-02-2006 18:46
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
program download problem zdeswarte Programming 5 23-03-2005 06:46
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
