Go to Post This is still about fun. Remember that. - Koko Ed [more]
Unread 26-01-2007, 09:42
TJ4nier TJ4nier is offline
Professional Stress Monger
AKA: TJ
FRC #2168 (Fitch CyberFalcons)
TJ4nier is an unknown quantity at this point
Send a message via AIM to TJ4nier
Air recievers...?
We just unwrapped our "Clippard air recievers", and are unsure as to how they work. No one on our team is particularly skilled in pneumatics, and we're having a pretty tough time, aside from all of the rookie team stuff.
Can anyone offer an explanation?
Professional Graciousism?
Gracious Professors?
Profess Graciousness?
No. Listen to the "W-Dawg" Flowers!
It's GRACIOUS PROFESSIONALISM.
Unread 26-01-2007, 10:15
Re: Air recievers...?
The Clippard tanks are simply for storing extra compressed air, so you can use your pistons quickly without waiting for the compressor to fill them.
Have you looked at the Pneumatics Manual?
It has a sample pneumatics setup to guide you.
Unread 26-01-2007, 11:20
AKA: TJ
We've somewhat skimmed through it, but as I said, we really don't know too much about what we're doing. And I don't see pneumatics as a "guess and check" sort of thing, so we're sort of afraid to just go messing with things.
But something that I didn't see explained in the pneumatics manual (as I just skimmed through it again), is how to attach the cylinders to...well, anything. They have green covers over the ends, which I'm somewhat afraid to remove. (Sorry, we're a rookie team running purely off of our KoP, and we really can't afford to break anything.)
What do we need to attach the cylinders?
Unread 26-01-2007, 11:35
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
You need to thread in the NPT (nominal pipe thread) to tube adapters to the thread beneath the green caps. These parts came in the SMC bag that you recieved this week.
In case you you are not aware NPT is a tapered thread so you DO NOT need to bottom out the fittings as I have seen many try to do. You need tighten them until they are snug with an approiately sized wrench (not a 12" adjustable) and leak check at low pressure.
To attactch them to your robot just use hose clamps or zipties.
The recievers are used to store air at 120 psi before it is regulated down for the rest of the system.
Pete
Thank-you 294 & 67
www.bobcatrobotics.org
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
are the green covers rather small, and made of plastic, and centered in the both ends of the recievers? if so, then they are just shipping plugs, their purpose is to keep dirt out of the recievers until you are ready to install the threaded fittings into them. Take them out....see how empty the recievers are inside....
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Air Jordan matt111 Rumor Mill 21 03-02-2004 18:59
IR recievers!?!?! tminard Electrical 5 24-01-2004 18:38
Air ship edomus General Forum 5 19-11-2003 18:17
Air Tanks geo Pneumatics 8 25-03-2002 15:13
