Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 26-01-2007, 10:41
ThatIndianKid89 ThatIndianKid89 is offline
FRC #0611
ThatIndianKid89 is on a distinguished road
Rubber Hose on the Spider Feet?!
Alright so,
At the Richmond/VCU kickoff event we were allowed to view the design of the rack. Though, we found something on the rack that was not on the game animation video nor the game revelation (i think?). There is a rubber hose about 6"-7" long sticking up from the top of the spider's "foot." We thought that this would make it slightly harder to place a tube on the rack, (both by dropping it on top and pushing it over and through the spider leg) so we have designed our robot accordingly. Can anyone confirm if this device will be present at the competitions themselves? Take a look.
Pictures (sorry for not resizing):
(sorry didn't have time to rotate it)
Unread 26-01-2007, 10:48
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Rubber Hose on the Spider Feet?!
That rubber hose is called the "stinger". There has been plenty of discussion about it around here, and it is definitely present in the manual. So yes, expect to see it at competition.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
It's called the "stinger", and it's in the rack drawings.
Unread 26-01-2007, 10:49
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Yes, the real field has the rubber hose - known as the stinger. It an 8" piece of J30R7 fuel hose, 5/16" ID. It is shown on the drawings for the wooden field as part T.
Eric
Unread 26-01-2007, 11:16
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
but the stinger in the design drawings is mounted lower down that it is on the rack you have pictured....so you might want to carefully check where it really is going to be instead of assuming that the pictures you posted show it correctly.
Unread 26-01-2007, 12:26
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
I wanted to ask you guys who have built a field with the stingers, how hard is it to flex the stinger? our teams arm is just long enough that we will still hit the stinger when putting the tube on. It looks like it is pretty malleable, but i don't know first hand. We will get some of this stuff at some point, i just want to know if it will be a problem or not.
thanks
--Dan
Unread 26-01-2007, 12:39
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
thanks
--Dan
It's not hard (requires very little force to bend), but it isn't paper either. Simply throwing a tube at the stinger won't bend it, you will actually have to push it a little.
For us the stinger seems to make it harder to get tubes off then it is to get them on.
Unread 26-01-2007, 12:47
I'm told that keeping the tubes from coming off too easily is precisely the purpose of the stinger.
Unread 26-01-2007, 12:49
The Arizona Mentor
AKA: Andrew
I believe it is. It seems to be harder to bend that direction.
Reflective Spider Feet? Plepel Technical Discussion 11 18-01-2007 14:46
pic: 36 Feet of CD Mark McLeod Extra Discussion 12 17-04-2005 21:13
handling loose wires/hose/cable Max Lobovsky Technical Discussion 5 24-02-2004 16:53
Pneumatics hose Brett W Kit & Additional Hardware 10 09-01-2003 15:35
Hose Clamps archiver 2000 1 24-06-2002 00:24
