Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Unread 21-01-2007, 13:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bottoming out on ramps?
There are other things you can do, one is to make a ramp that is angled all the way up, with no horizontal part, although you might need some type of brake to keep the robot from rolling back down when power goes off at the buzzer. Or make a teeter-totter ramp, that is angled all the way up and when the robot gets past the tip point, it falls back level.
Unread 21-01-2007, 16:58
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
Thanks for all the advice! Any other ideas out there? (Just trying to get a good, well-rounded consensus)
Unread 22-01-2007, 00:30
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Don't forget the fact that some teams will be using bumpers and some teams will not.
All else being equal those that eschew bumpers (us included) will have less issues with ramp bottoming than those that use bumpers. There were quite a few teams last year that discovered late in the build that the bumper added a whole new wrinkle when it came to maneuvering up the 30 degree incline.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 22-01-2007, 00:38
MrForbes's Avatar
AKA: Jim
OT:
ok, why is it that when we're talking about ramps, bottoming out, and bumpers, there are two guys with hot rods in their avatars in the discussion?
Unread 23-01-2007, 10:15
Brian C's Avatar
Doer of Whatever
FRC #1468 (J-Birds)
HA!
That's 'cause all us hot rod guys like working with mechanical things and robots fill that void during the cold months. I just wish the deuce was really mine........
Seriously, bumpers are sometimes a second thought with teams. The 30 dedgree ramp last year stumped quite a few people. We striving for 20 degrees or less to accomodate the majority.
Unread 23-01-2007, 14:34
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
OT: I'm going to WyoTech in June for STREET ROD FAB. sweeeet....
Unread 23-01-2007, 15:12
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
If you had no problems last year ramping, why not just design a similar drive train?
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 26-01-2007, 12:36
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Originally Posted by K.Porter View Post
We've designed a 4 wheel drive system which is very much centered at the front of the robot, with the back being supported by casters. That way, even if we do bottom out we will be able to drag ourselves up a ramp with the front wheel drive.
As for our ramp, we have allowed for a shallower angle than last year's playing field, and we hope to round the top corner.
If I understand your idea correctly, it should work if the center of gravity of your robot is balanced over your drive wheels to maintain contact with the top ramp surface. Otherwise you may find yourselves grounded on the ramp with your drive wheels in the air as the CG of your robots shifts to the back wheels when you go up the ramp.
Should this happen, you can always go up the ramp in reverse.
Good Luck!
Unread 26-01-2007, 13:16
Martinez's Avatar
Martinez Martinez is offline
Free Agent
AKA: Jeff Martinez
Martinez is a splendid one to beholdMartinez is a splendid one to beholdMartinez is a splendid one to beholdMartinez is a splendid one to beholdMartinez is a splendid one to beholdMartinez is a splendid one to beholdMartinez is a splendid one to behold
This is the number one reason I think ramps are a bad idea. There will be plenty of teams who won't or can't climb a ramp. Its a great thing for most alliances but this really is something you have to design around. I feel that if you are going to come up with a way to lift robots: than it should be universally compatable for as close to everyone as you can, not the other way around. Aside from that, 2" or 15 degress seems rather popular.
Jeff "Martinez" Martinez
Mechanical Engineer with JH Robotics
Clarkson University and Division by Zero Alumni
Former 2053 Tigertronics Mentor and Engineer
Former Chuck 84 Mentor and Engineer
Former Lockheed Martin, VH-71 Program Employee.
Let us never rest till every student has FIRST Rate Opportunities!
Program Proposal: FRC
Unread 26-01-2007, 13:44
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
people building ramps need to take into account that other teams aren't building their robots to accomodate ramps. This is the reason 1741 chose to go with a lifting system. My recomendation is if your ramp is greater than 2 inches tall it better have a slope less than 20 degrees, or else no one is getting on.
Unread 26-01-2007, 15:16
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Our ramp will be about 8.5 degrees so everyone should be able to go up it with very little trouble. Robots wider than 40" need not apply. See you at the tournaments.
Dave
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
Unread 27-01-2007, 03:12
Elpants's Avatar
Elpants Elpants is offline
FRC #1566 (Ammoknights)
Elpants is on a distinguished road
Send a message via MSN to Elpants
Our bot completely folds up to 13" tall 26" wide and 37" long arm and all enclosed.
With the smaller wheels this year most teams I suspect will have a lower ground clearence. I was playing around on a white board with scale drawings to see the best kind of angle our ramp should be. As it is right now our own bot (with a ground clearence of 2 3/8" cannot even make it up our own ramp that I have drawn up for inventor with-out high centering on the corner..
Our deadline for a working chassis with arm is to be finished tomorrow, all our programming was getting finished up last night. So I need a general average of ground clearence so I can design our to accomidate the average team. (That, or I hope a lot of teams have 6wd/treads )
Unread 27-01-2007, 09:56
1768's Avatar
1768 1768 is offline
FRC #1768
1768 is an unknown quantity at this point
Originally Posted by Scott358 View Post
In the end, regardless of how you do it (ground clearance, skid pad, 6 wheel drive, etc...), you definately want to keep ramp climbing in mind (assuming you're not the ramp!).
Given the abundance of ramps, keep ramp climbing in mind even if you ARE the ramp. e expect to be on at least one team where the entire team is ramp-bots, so we are designing to climb a ramp and be a ramp low-clearance bots can climb.
Unread 27-01-2007, 10:07
MrForbes's Avatar
AKA: Jim
Have you considered the implications of rule <G29> on the starting configuration of this design?
Unread 27-01-2007, 12:00
Elpants's Avatar
I guess I should be more specific, this is w/o a ramp and all electronics and drivetrain within these dimentions, just stating that with a plateform height of 13" its getting hard to create a ramp that is under 4' tall and wont have a problem for our own bot to get up w/o getting a running start.
our height changes, at the end of the game, the robot is 13"tall.
ramps for robotics rijo664 Technical Discussion 2 16-01-2007 11:12
Ramps ideas Andrew Schuetze Technical Discussion 2 14-01-2007 01:20
Gate Ramps KWB@FIRST General Forum 14 17-10-2006 23:38
Sticking Ramps and Fat Goals! archiver 2001 5 24-06-2002 01:47
Overall Dims of ramps & field from CDI 1999 archiver 2000 0 24-06-2002 00:08
