Go to Post WE might have a different plan than being overweight, but thats just my guess - pakrat [more]
Unread 26-01-2007, 14:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: interupts 3-6??
I think you have to read the entire port to be able to clear the flag, but reading a single pin might work. What happens is if you don't clear the mismatch by reading the entire port, or maybe reading one pin, is the flag continues to be set over and over, and you'll keep jumping back into your ISR. So if you try your way and get a red light of death, you'll know why.
Second point. Your method works if you only care about 0 to 1 transitions on the pin. 1 to 0 transitions will still cause interrupts and you'll still have to service them, however. So using interrupts 3-6 when you only care about 0 to 1 transitions is pretty wasteful of your resources and you'll only be able to service half as many interrupts as you'd other wise be able to.
Interupts/sec cprogrammer Programming 9 12-10-2006 12:46
Interupts on Vex in MPLab Andrew Schreiber FIRST Tech Challenge 1 24-05-2006 08:32
Interupts on the Pic18 Andrew Schreiber Programming 10 21-01-2006 22:54
Interupts? Validius Programming 6 11-01-2006 18:29
Need interupts help, and another question... Kevin Karan Programming 7 22-02-2004 11:20
